Question about HP DesignJet 500 InkJet Printer
False ink empty
We have a customer's DesignJet 500 printer that says all the ink cartridges are empty - it is flashing four exclamation points, and the display says to install ink cartridges. All four inks are new, but the Magenta is empty. We had a bad ink tube assembly that drained the magenta ink right through. We replaced the ink tube assembly and the ink supply assembly: the box that holds the cartridges and includes the ink sensors. Black, Cyan, and Yellow are still completely full - I can feel the weight of the ink in them, but the machine insists they're empty. Does it need a new main board, or am I neglecting something else?
  • HP Master
  • 1,121 Answers
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Posted on Dec 04, 2012
  • 1 more comment
  • Eric Sandbo Dec 04, 2012
    Thanks. I'd started on the refilling proceedure, but was held up by this error. I had a replacement Magenta ink ctg. left, and installed that, and it's error went away, showing a full ctg. I believe the machine is insisting on band-new cartridges, even though it hasn't printed a drop of ink from the new ones I put in before replacing the tube assy. Apparently the chip in the ctg. says it's been used, and the printer rejects it, though it still reports that it's filled to capacity. I have the other three colors on order, and I think that it will start the filling process when they're installed. I was also thrown off by the fact the machine's display never tells me to put in the dummy cartridges. It says to remover the real ones, and I had the dummies standing by, waiting to be prompted to install them. There is no such prompt in this model; I just have to put them in when I take the real ones out.
  • Eric Sandbo Jan 04, 2013
    I wrote that this model does not prompt me to install the dummy printheads used in the ink tube filling utility. I was wrong - I just hadn't made it that far. It tells me to remove the real heads, then, one or two steps later tells me to install the dummy heads. Until I had the new ink cartridges I couldn't get to that point.
  • Vinaya Kumar Kuchipudi
    Vinaya Kumar Kuchipudi Jan 04, 2013
    As per your previous information you don't have dummy print heads, Am I right?. Order for dummy print heads or find out used dummy print heads, this is only option in front of you..Part No for dummy print heads C7769-60164..Once dummy prints are arranged do the following process. 1. check do you have dummy print heads 4 nos. 2. Normal print heads 4 nos, in good health condition ( if print head nozzles are clogged/dried up, priming will happen but print head alignment will not happens). 3. All cartridges should be original with minimum 50% ink levels required. low ink levels, refilled cartridges are not allowed... Work Process: Take out print heads & cartridges from the printer. Press & Hold up & down arrows power on the printer, wait till service menu appears on screen, release keys,scroll to service utilities, enter.. scroll to Ink tube replacement... enter..follow the screen message..(Printer performs to replace ink tube assm ask to switch off for replace the ink tubes, just switch off the printer wait little whilw switch on again) insert cartridges one by one later dummy print heads, once priming is completing printer ask for normal print heads, follow the screen messages care fully..once every thing is through, printer will perform print head alignment..once its completed,printer is ready to print..# Before replacing any part pl read the installation procedure comes along with the part.. You are troubled because of not reading the installation manual.. Still if you are facing any problem pl mail me: vinay229229@yahoo.co.in..
    Problem Solver:
  • 10 Answers
You may be going too far with the repair,
It may be that the old tube system has incorrectly updated trhe cartridge chipset. the first thing you should try is a NEW set of HP Original ink cartridges. This is a problem I have seen many times 1 poor cartidge chip can ruin a full set ( all Coluors) and until all cartidges are replaced each new single insertion writes off anothe ink cartidge as fully used when its brand new .
Posted on Jan 02, 2013
  • Eric Sandbo Jan 02, 2013
    It was the ink cartridges. Each one has a chip inside, and I guess the printer recognized them as having been installed before the ink tube assemble was replaced, therefore they were not new. The printer needs a lot of ink to fill the new tubes, and refuses to accept cartridges that aren't brand-new, so it marked these ones as Empty, even though it recognized that they still were at 99% capacity. Odd and unhelpful, but that's how it looks. Replacing the other 3 colors fixed everything. The machine recognized them as full, ran the ink tub filling utility, and prints beautifully. I called HP tech support, and they sent replacements inks to the customer, who returned the "empty" but full ones to HP.
  • 125 Answers
SOURCE: ink cartridges
Go through your standard print procedure. File>print then look for the properties button which is usually on the top right of the window. Press Properties and look for either Printing in B/W or grey scale. That should prevent your color cartridges from printing. After you check that box, you should be able to print black only.
Posted on Aug 19, 2008
  • 990 Answers
SOURCE: Color washed out
Hello sir; Try to clean out scanner mirrow, see what happen!
Posted on Apr 23, 2009
websnail
  • 419 Answers
SOURCE: A blank page when coping or printing in black.
As with all of the solutions I've provided on this and the other HP88 printers, the problem is that the black printhead has become clogged due to the conditions the printer is kept in.
For some reason the pigment black ink in the HP88 printhead is particularly prone to clogging when used in hot, dry conditions where there is air conditioning or similar...
The only solution I have found to date is to replace the black ink with a dyebase alternative and use that with a new printhead. Finding this solution took me about 14 printheads and a lot of head scratching so it wasn't easy...
Finding a dyebase alternative may be difficult but whatever you do, make sure you purchase a remanufactured original HP OEM, not one of the all plastic designs with no black rubber bulb in the bottom of the printer. They fail and leak a LOT!.
Hope that helps..
Martin
Posted on Jul 11, 2009
  • 102 Answers
SOURCE: I installed two new cartridges,black and magenta.
If you have successfully installed ink cartridges before, tried powering down and back up again, posted for a solution on FixYa, then your printer must be factory-serviced.
If you are changing ink cartridges for the first time, find your manual and do the procedure step-by-step. The cartridge-moving mechanisms and sensors are delicate and must operate in a specific sequence.
Never turn off a printer while it is still making noise (unless there is smoke). Check that the protective tape has been removed from the cartridges before installation. Check that the cartridges are firmly seated by visually inspecting that they are lined up with the other cartridges.
Posted on Oct 07, 2009
cene765
  • 787 Answers
SOURCE: I have a HP CP1700
Make sure that printer ask for ink cartridges.It can ask for yellow and magenta print heads!!!Check this again and if need replace the print heads.
Posted on Nov 20, 2009
Hi Vinay kumar kuchipudi , I tried using refillable cartridges and my CYAN is always flashing . rest of the cartridges is reconised. Can you please advice me what to change. I tried the second new ref
Sorry for the delay.,
As you know each cartridge having memory chip, the chip keeps the estimated level of ink inside as per the out put print volume . But there is no contact or any internal circuit to link up with the chip.. Once its empty, even refilling the ink inside chip wont recognizes the ink level, results printer detects that cartridge running out of ink & printer warning appears on panel. You need to replace the chip while refilling the ink. Now a days universal re-settable chips are available in the market, get the set of chips replace with existing chips..
Nov 05, 2014 | HP DesignJet 500 InkJet Printer
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
HP DesignJet 500 - Printer will not recognize any of the four ink cartridges
>Remove cartridges,
>Remove right door,
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm both will loose their memory..be careful..
Hp designjet 500 is saying ink cardridges are empty but thay are new
Here is a link where you can download a copy of the owner's manual for your printer:
http://h10032.www1.hp.com/ctg/Manual/c00748239.pdf
In the manual are detailed explanations of error messages, what to do if it won't print, how to clean the print heads, how to align the print heads, and so much more. Shown here is a page from your the manual regarding ink supply issues. (Zoom in to make print bigger)astucia01.jpg
Apr 18, 2011 | HP DesignJet 500 InkJet Printer
I want to refill my hp1050 cartridge. but i don't know how to refill this. so help me to refill it.
Hello thanks for using Fixya
HP DesignJet 1050c plus InkJet Printer refilling the cartridge is not difficult, but it is important to use the appropriate technique.
Download this Service Manual. This is going to help you out briefly
Manual will be in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
To further help see this video that how can you refill Inkjet Printers, It will going to help you out too
You must do care by doing this. Otherwise go to any HP service center and give them your empty cartridge they will surely refill it.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Hp Designjet 500 not recognising ink cartridges. the ink carts were nowhere near empty but coming but the printer says replace bought new ones and put them in and the machine is not recognising them...
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Jul 15, 2010 | HP DesignJet 500 InkJet Printer
HP Designjet 130 shows no ink on display but cartridges are full
Remove the cartridges and give them a good shake - this should fix the problem!
Aug 10, 2009 | HP DesignJet 130 InkJet Printer
Hp designjet 500 (42'')
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Jun 16, 2009 | Office Equipment & Supplies
One cartridge missing!
its best to leave all the cartridges in the printer even if they are empty. the printer will continue to print but with the absence of yellow any color printing might be off color. black and white printing should be unaffected.
Feb 02, 2009 | HP DesignJet 500 InkJet Printer
HP DesignJet 500 InkJet Printer Logo
1,095 people viewed this question
Seeker5211
Seeker5211
