Question about GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPABS Freezer is not working and everything is melting
    Top Expert:
  • GE Master
  • 9,472 Answers
Is the compressor kicking on? Check to see if it is warm.
Posted on Dec 03, 2012
SOURCE: We have a GE side by side, freezer side started
I have the same problem, I am not hearing anything running either, but the lights are working. Everything on the top is warmer than what is on the bottom. Any help would be appreciated.
Posted on Dec 21, 2010
  • 85 Answers
SOURCE: GE SxS GSL25JFPABS freezer will not freeze
When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor
Defrost thermostat:
During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a closed circuit again. A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire.
The defrost thermostat is located near the defrost heater and is wired in series. It is usually located at the back of a side by side freezer, behind the freezer back wall of a top freezer or under the floor. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer. At room temperature the defrost thermostat is an open circuit ( no continuity ) and when cooled down the defrost thermostat closes the circuit ( has full continuity ) to allow the defrost heater to come on.
Posted on Feb 26, 2009
  • 28 Answers
SOURCE: GE model gsl25jfpabs, freezer is cool like
Look for frost on freezer back wall.
dirty condenser, condenser motor not running
bad compressor
Posted on Mar 03, 2010
  • 11800 Answers
SOURCE: GE Profile Side by Side
The temperature setting in the fridge section of your refrigerator is generated by diverting a part of the cold air generated in the freezer. This is done with the help of a fan and is controlled with a thermistor. If the temperature doesn't drop low enough then either the fan is faulty and it will have to be replaced
http://www.appliancepartspros.com/part_details.aspx?part_id=3875639
or it's not properly commanded because either the thermistor is faulty
http://www.appliancepartspros.com/part_details.aspx?part_id=3185407
or the control board itself has failed and it continuously activates the defrost resistance
http://www.appliancepartspros.com/part_details.aspx?part_id=4436216
If you need diagrams you can find them here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5236940&diagram_id=23953624#d23953624
Posted on May 28, 2011
SOURCE: hi. I have a GE Monogram refrigerator/freezer
I have zfsb26dnd and it does not freeze or cool ther refigerator
Posted on Oct 13, 2012
My GE refrigerator GE GSL25JFPABS stopped cooling on both the frig and freezer sides. I pulled it out, took off the panel and cleaned around the fan. I plugged it in and it worked perfectly for just less...
you may have a defrost problem, check for frost in freezer, back wall, or pull off rear panel and check evaporator, it should have some frost on coils, if frozen all around evaporator, check glass element at bottom of evaporator, should have blue and pink wire going to element
Aug 22, 2010 | Refrigerators
Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
Mar 31, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE model gsl25jfpabs, freezer is cool like refrigorator, but won't freeze....
bad compressor
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE gsl25jfpabs Profile. Water stopped coming out of dispenser. Frozen? New valve? Help
Yes, probably frozen. Open the door, minimize the freezer setting in the refridgerator section, and try out the dispenser every once in a while until you get water to flow. Might take a couple of hours so make sure you have a backup freezer or a big cooler for your food.
Feb 08, 2010 | GE Refrigerators
My refrigerator is not cooling the freezer works
We have this refrigerator and what you described is a chronic problem. (I hate this refrigerator!) Our repairman got tired of hearing from us so often and told us how to fix it ourselves! Take everything out of the freezer side and unplug it. Remove the white back part inside the freezer part. There are 2 screws at the top. The inside will be full of ice. Melt the ice with warm water. It makes a huge mess so get lots of towels. Once all the ice is melted you can put everything back and plug it in. It may take a day for it to get really cool again. My long term advice is to get a new refrigerator...
Jan 05, 2010 | GE Refrigerators
I have a GE Model #GSL25JFPABS fridge. My freezer has been frosting up for quite some time with the ice cubes melting a bit and freezing together. Recently the fridge side has also been warming once in a...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 29, 2009 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE Profile PSC23. Everything works fine
I fixed it myself. After poking around the freezer, I saw that the area around the tube that gets water for ice making was frozen - this is at the top of the freezer. So I used a hot spong to melt the ice and the noise went away. Everything is working fine now.
Jun 17, 2009 | GE Refrigerators
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
Defrost thermostat:
Feb 26, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
161 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
