Question about Nikon Coolpix S210 Digital Camera
LENS ERROR ON COOLPIX L3 CAMERA
I WAS TAKING A PICTURE ON THIS CAMERA AND LENS ERROR CAME UP AND WON'T GO OFF. i CHANGED BATTERIES AND THAT DIDN'T WORK PLASE HELP Camera will turn on but the screen says Lens error
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 98,762 Answers
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
Took a picture, then camera was in bag for a moment with lens open. when I tried to take another picture it was blurry, then the lens got stuck , "Lens error", kept making noises, had to take batteries...
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 18, 2010 | Nikon COOLPIX L3 Digital Camera
Not the same problem but hope this helps. I went to get it looked at by a dealer and they said it would cost 180 bucks. They said it was not worth it. Ok this is what I did to fix it. Mind you it can be a little difficult for the not so tech savy. First remove the batteries, then take all the screws out on the outside of camera, dont forget about the 2 under the battery cover and the one in the AV port. Carefully use a small flat tip screwdriver to pry the two plastic covers off. The hard part is over, now pull up the LCD, it is stuck on by double face tape. There is a silver cover 3 more screws to remove. Ok now for the easy part. Where the screen attaches to the motherboard there is some black tape low and behold under it is a connector. On my camera it was not connected very good. I pushed it back on and put it all together and now it works. 180 bucks saved. Hope this helps.
Dec 28, 2008 | Nikon COOLPIX L3 Digital Camera
Coolpix l3 lens error
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
NIKON COOLPIX L3
See my posts on this problem. By forcing the lens with you fingers into the camera, it may put it on track. This can damage the camera even further, but may be worth a try. You can try to pull it out when starting, and then pushing in on turning it off.
Worth a try, may work.
Apr 12, 2008 | Nikon COOLPIX L3 Digital Camera
Seeeking help with new CoolPix L10 "Lens Error"
I sorry to tell you that the user manual is correct. There would be little you could do yourself and if you would attempt any repairs, you would void your warranty.
To make the best of a bad situation, I recommend setting the camera to its highest resolution mode and taking all your picture in the wide angle mode. You can crop the larger images when you get back home and still have printable pics
Dec 30, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
71 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
