Question about Lenovo ThinkPad R52 PC Notebook
Lenovo R52 think pad makes 4 beeps after computer has been on awhile. Once it starts beeping there is a small break and then it beeps again 4X.
    New Friend:
    Problem Solver:
  • 9 Answers
Four cycles of four short beepsand a blank screen.Problem:----> System board (security chip)
Do you still have warranty?
Try pulling out memory sticks and putting them back in.. here is something I found. Might help.
For reseating instructions (for my T42p), I used:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46513.html
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46515
and a video, which reminded me that there was one more screw to remove(!):
http://www-307.ibm.com/pc/support/site.wss/MIGR-50227.html
Posted on Dec 03, 2012
freddygon66
  • 93 Answers
SOURCE: my lenovo n200 does on turn on it beeps and screen remains blank
Hi, you must remove both memories and return to wear them in the socket, it is for it that your equipment not power on correctly
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: lenovo laptop with terrible beep-sound when power-supply are plugged in- and out
If you're using to Lenovo Ideapad U330 click on the volume setting and go to options: properties.
Select PC Beep and then adjust the volume to your desired level or mute completely
Posted on Dec 22, 2009
halbrook
  • 560 Answers
SOURCE: t500 lenovo kepps beeping and wont turn on it just
remove the power supply and battery then remove the memory module, clean the memory gold contacts. a regular pencil eraser will do. return the memory then the battery.
Posted on Apr 19, 2010
archiecruz30
  • 187 Answers
SOURCE: my lenovo netbook s10-3 is
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute.. - plug back in the charger - after few secs try to turn it on
or if beep persist try to reseat your pc memory ( make sure you know how to do it or you can try to look on local tech in your place)
if problem still persist you can contact Lenovo tech support on this number 877-453-6686
hope this helps :D
Posted on Apr 05, 2011
mand25
  • 18 Answers
SOURCE: What does 4 beep codes
Four cycles of four short beeps and a blank screen...
System board (Security chip)
Posted on Jul 14, 2011
Microwave was beeping a single beep once in awhile now nothing happens but the clock still works
A lot of the time when that happens the touch pad is bad and may have a colappsed air pocket on a pad. ( it makes the unit think you are pushing a pad ) The only way to fix it is to replace it (the touch panel) . Did you see any numbers coming up in the display. Like if the 3 pad was bad and making it beep it may have been showing a 3 in the display,. Always possible it could be a bad main board. But most commonly I have found it to be the touch panel. Try to unplug it and then plug it back in and try to set the clock. when you do, try each number pad and see if they all work. See if any feel different.
Oct 17, 2017 | In Microwave Ovens
How to reset lenovo thinkpad r61?
Please follow the steps below to reset the lenovo to factory settings
Note: All your data will be lost. So keep that in mind.
So take the backup of your data first in a separate HDD or flash drive.
1. Switch off the Computer
2. Press the power button and then immediately start tapping f11 key on the top of your keyboard.
3. You will hear a beep sound and then stop pressing it.
4. You will get the screen says windows is loading files. Wait untill it finishes.
5. Select the default language which is US and Click on next .
6. Enter your login credentials (username and password) if you use to login to the windows.
7. Then you will get the system Recovery Options screen where you need to select the last option "Lenovo Product Recovery"
8. Again preferred language will be English US and hit Next.
9. Accept the terms and conditions and hit next and then hit Yes on the warning.
10. Then it will start resetting the Lenovo Think pad to the factory default with no previous data. Same as when you purchased it.
If you have any query you can ask before restoring the Computer.
Hope this helps you. Reply if that fixes your issue.
Sukhiii
May 07, 2014 | Lenovo ThinkPad R61 Notebook
Lenovo beeping
Remove the Battery pack and Insert it again, I will work again.
Jan 09, 2018 | Computers & Internet
Lenovo K410 beeps, WILL NOT START
3 beep might be memory error, take out your memory and try reseat them nicely. dun break the slot holder. if still no picture, same beep,
replace with good one. if still the same prob, replace display card if there is. if still no sign of booting, pls take back to service centre.
Jan 08, 2014 | Lenovo K410 11681LU Desktop PC Windows 7...
High pitched long beep
disconnect the batt or the computer a few min and see if it clears--if not then hav vehicle scanned
Nov 21, 2013 | Nissan Cars & Trucks
My computer has 3 beeps followed by 4 beeps and it is not displaying on the screen
Sounds like a bios error code. If you have a store brand PC like HP, Dell, Gateway there will be a section describing the beep codes, some manufacturers also have a series of 4 led lights on the back of the PC that correspond to different problems. Have you recently added RAM or other components to your PC?
Aug 02, 2013 | IBM ThinkPad R52 Notebook
I have a long beep that happens every once in awhile while driving my 2001 cad. catera
if talking about horn beeping more likely horn pad has short worn out or horn wire grounding inside steering wheel. your horn have garage check it out because horn pad buttons and airbag is whole assembly in the steering wheel..
May 16, 2013 | Cars & Trucks
Lenovo 3000 J Series won't boot up. It beeps 4 times and does nothing.
the only beep code i can find for 4 beeps is a keyboard error. if you're using ps/2 you should make sure you haven't put the plugs in the wrong ports. i found the information here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/thinkcentre_pdf/41t3751.pdf
page 75
Feb 16, 2012 | Lenovo Computers & Internet
R52 thinkpad not boooting. making beep sounds on start up.
Welcome to Fixya
Beeping sound is telling you there is something wrong with the hardware. Different beeps has different meaning. Please refer to this link for the standard beep codes of your computer.
Hope this helps.
Thank you for using Fixya!
Mar 26, 2011 | IBM ThinkPad R52 Notebook
Computer doesn't start, only beeps
4 short beeps = System timer failure!!!!
here is a web address that will be able to help you resolve the problem:
http://www.computerhope.com/issues/ch000607.htm
good luck
Nov 16, 2008 | Lenovo ThinkPad R61i 14 inch widescreen...
Lenovo ThinkPad R52 PC Notebook Logo
111 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
