MITS. TS-4553 with SOUND but no picture?
Everything turns on and you hear the sound but the picture wont come on.
  • 3 more comments
  • robm1391 Jan 11, 2009
    How am I suppose to update the drivers and Motherboard?
    Not a repair man.. where would I look for this?
    Would anyone have a best guess on getting it repaired? Is it worth it as it is pretty old.. but was working great so that is why I am asking about fixing it.
    anyone with exper. with this.. would happen to know what it might cost?
    Genius:
  • 1,239 Answers
Hi Probably bad capacitors. My 52525 has the same issue using component cables and tech said the capacitors on the formatter board has to be replaced. Part back ordered
http://www.hdtvoice.com/voice/showthread.php?t=33963
Posted on Jan 11, 2009
    Sergeant:
    Novelist:
  • 326 Answers
It will cost you near to 50$ for the paRTS plus the technicians service charge. THANKS.
    Sergeant:
    Scholar:
  • 199 Answers
Its the problem of ic on your board and you will have to get it replaced to get the picture.just get the ic replaced and it shpould work.a normal tv repair center is much advisable.
thanks.
  • 10,594 Answers
You should contact local TV tech for proper fix. TV seems have problem in horizontal deflection section and qualified TV tech will repair it properly.
Good Luck.
  • Shahid Electronics
    Shahid Electronics Jan 11, 2009
    Worth to repair would be puelry your decision and you can decide it by asking an repair estimate to TV Tech. If estimated cost of repair is greater, then new TV is better choice.
    Genius:
  • 2,920 Answers
You might want to call a service man out to fix it.with all the different answers you can get on here theres no telling where you might end up.play it safe call a repairman
  • Ronnie Houston Jan 11, 2009
    probably about 300 or less to get it fixed
  • 43 Answers
Update you driver to the grapic card, and motherboard, the game you aer running might be dmg some how. if it's a cracked version
  • 19,396 Answers
Tv driver motherboard is not an answer that does make sense, "resoldering the vertical output IC this is acommon problem with this model" makes sense, but was a guess.
Try first unplugging your Mitsu from power for some times, this may not fix the problem, but must be done.
Try switching input channel on the remote , and see if picture comes up from DVD or external receiver.
Check if PIP is activated, there is a fault related with PiP that returns sound but no picture.
You can also try wacking gently the TV, if the picture comes back , then it is ab broken contact inside the TV, easy fix for a technician. Be careful not to damage the TV while you do the whack test.
If it is none of the above then it is an internal fault.
If you are a tv repairer, look for broken solder joints, and start testing the output transistor, and the resistor between the base and emitter of the trans on the orizzontal output circuits.
If you haven't fixed tvs before use the phone number listed on the owners manual to call support.
  • Ginko
    Ginko Jan 11, 2009
    The base cost for a tech is $80 base plus part, I think the average cost is $120/$200, if there are no expensive parts involved.
    If the TV is not too old you can buy a warranty extension that will cover the whole job cost.
    President:
  • 2,110 Answers
Try resoldering the vertical output IC this is acommon problem with this model
  • Sibananda Jena
    Sibananda Jena Jan 11, 2009
    It is better to contact a technician for this...
Mitsubishi Model Ts 4553 picture dull and dark will cleaning the inside help or do you think I need a bulb replacement
You will want to clean lens and mirror when you replace the bulb so why not try it first. Avoid glass cleaner with amonnia as it will ruin mirror.
Oct 20, 2014 | Televison & Video
I changed my bulb to weeks ago and now it wont fire have sound and no picture i have a wd 73c-10
Did you use a generic bulb or a "Neolux" lamp--Mits does NOT like those. Use a Phillips bulb or an original NON neoloux one.
Apr 01, 2014 | Mitsubishi Televison & Video
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My Mits 62"initially has no picture and loud noise until warms up
all of these tvs had bad caps.. that is probably your issue, as they can cause lots of symptoms.
here is my tutorial on this
http://www.fixya.com/support/r5069371-mitsubishi_led_keeps_flashing_green
Let me know if I can be of further assistance.
Jun 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a samsung HLR 5078 that wont turn on. makes winding noise
it does sound like your color wheel.If that sound is more mechanical than electrical then it would be the color wheel.
Apr 15, 2010 | Samsung HL-R5078W 50" HDTV
52" LG DLP
you may have had a power surge
Jun 17, 2008 | LG RU-52SZ30 52" Rear Projection...
Repair of a Mitsubishi TS-4553 46" rear projection television
I checked out past posts on your forum and found the answer there. The TV is working great. I did have a bit of trouble finding the cc in the menu, but finally found it and the problem was solved by turning the cc off. Now I just have to make sure that they don't turn it back on!
Thank you!!!!!
Feb 18, 2008 | Televison & Video
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
