Question about Kenmore Kitchen Ranges
Kenmore gas oven, model 790.71409700, code f30
  • 86 Answers
SOURCE: stove oven does not workit,s a kenmore stainless steel
This is the info I found on that.
An F30 error code indicates either an open or shorted probe connection. This sensor is referred to as an RTD (resistance temperature detector) sensor probe. There is a sensor just behind control panel on right side located in the oven sensor wiring harness. Opening or shorting of this sensor will cause an F30 error code. A loose connection or faulty wire harness between the EOC (electronic oven control) and sensor could cause the failure. It could be the sensor is simply unplugged.
Posted on Jan 20, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
protek480
  • 1714 Answers
SOURCE: our figidaire electronic stove/oven model
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Posted on Sep 26, 2009
SOURCE: Kenmore electric Range 2005
we are baking at 350 and we just received an F30 error and the oven shut off. can you tell me what this means
Posted on Nov 26, 2009
  • 119 Answers
SOURCE: Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Posted on Jan 14, 2010
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
F30 oven won;t come on and
since how long are you getting this error ?
Jul 21, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
When I push the Bake or Broil buttons on my kenmore stove it beeps F30. I do not have a self cleaning oven. The gas burners work fine so I know we have a clear line. What can I do?
Log on to the Kenmore website and click on support. Enter your model number and go to troubleshooting. There you should find what your trouble code means. murf427
Oct 24, 2012 | Kitchen Ranges
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Gas range. Oven does not work and F30 alarm displays.
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Nov 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F30
My kenmore gas range displays F30 when I turn the oven on
F30 ERROR
F30 error every time I turn the oven on
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
35 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
