Question about Lexmark All-in-One Printer with PictBridge
Printing stops halfway
I have just changed the ink cartridges on Lexmark 2500 (original Lexmark Cartridges)and when i go to print the first page as reqired the paper just stops going through. I have tried everything, including uninstalling and reinstalling. Can you help.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Printer will not print pages. Blank paper comes shooting out
clean heads and align clean cartridges,next time use original dell cartridges no refills or over filled ones
Apr 24, 2015 | Dell Photo 926 All-in-One Printer
Lexmark pro901 stopped printing black ink
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update. Also, make sure that you're using genuine Lexmark cartridges. If not, replace the cartridge.
Jul 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Lexmark prospect pro 205 not supported by this all in one
Please make sure you are inserting genuine Lexmark cartridges. Lexmark printers work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 26, 2012 | Lexmark Prospect Pro205 Wireless...
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
Replaced the ink cartridge and it is not printing
Try to check your ink levels. On your computer, go to Start menu > Programs > Lexmark 2500 Series folder > Lexmark Solution Center. If ink levels are substantial for printing, go to the Maintenance tab and select Clean to fix horizontal streaks. It could be due to clogs and dirt in the cartridge nozzles caused by long periods of non-usage.
If the light continues to flash for both cartridges, try to replace both cartridges with different known working cartridges or better yet, replace them with new genuine Lexmark supplies.
Dec 05, 2011 | Lexmark X2500 All-In-One Printer
The black ink has stopped printing. Put in two different new cartridges and that doesn't seem to be the problem. It was first noticed when photos were printing out funny even after changing the color...
Make sure you are inserting genuine Lexmark cartridges.
Try to clean the cartridge nozzles. Refer to the steps below:
Cleaning the Print Cartridge Nozzles:
1. Open the Lexmark Solution Center. Click Start > Programs or All Programs > Lexmark 1300 Series. Select Solution Center.
2. From the Maintenance tab, click Clean to fix horizontal streaks.
3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
4. Print the document again to verify that print quality has improved.
Using the control panel
1. Press Menu.
2. Press the down arrow button until you highlight Clean Cartridge.
3. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
Oct 13, 2011 | Lexmark P4350 All-In-One InkJet Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
98 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
