P0700 Transmission Control System
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System -Electrical
P0703 Torque Converter/Brake Switch B Circuit
P0704 Clutch Pedal Position Switch -Circuit Malfunction
P0705 Transmission Range Sensor/Switch Circuit Malfunction (PRNDL Input)
P0706 Transmission Range Sensor/Switch Circuit Range/Performance
P0707 Transmission Range Sensor/Switch Circuit Low Input
P0708 Transmission Range Sensor/Switch Circuit High Input
P0709 Transmission Range Sensor/Switch Circuit intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine RPM Input Circuit
P0726 Engine RPM Input Circuit Range/Performance
P0727 Engine RPM Input Circuit No Signal
P0728 Engine RPM Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit
P0741 Torque Converter Clutch Solenoid Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
Now i dont know a lot about automatics especially modern ones with all this fancy electronics thats used nowdays but i think its a fault with the temperature sensor for the gearbox.But where its located and what it looks like i have no idea it could even be mounted inside the gearbox .Sorry not a very good answer from a mechanic but?? very few of our europeon cars come with auto transmission .Evan when i do know whats wrong i cannot buy the parts for the gearbox as only re-con boxes supplied by the dealer so best advice is to try a specialist in auto box repairs only .PS some of my best students when i used to teach mechanics many moons ago were the girls so no excuses like iam only a girl please
I've changed the aspect on the sky box and if the tv is in normal and the sky box is in 16:9 the picture is compressed. If I put the sky box in 16:9 and the tv in auto it'll work but the programs in 4:3 will be stretched. I've tried every combination but I can get the tv to adjust. I've even disconnected the sky box and tried it off the basic ariel but again it wont adjust.
