Question about HP AX325AA Notebook Portable LED Projector Companion with Expandable Tripod for PC Laptops
Dmd board for hp notebook projection companion ax325aa
Install dmd board
Not hard to do....IF you have some electronics experience...but are you sure you do not just need the dmd CHIP? it is easier to install. The chip=---and board is removed from the engine--AFTER the engine is removed. Then the rear cover on the dmd board is removed--the screws for the chip removed and the board should lift out. DO NOT remove the front housing--or you will need to re-align the whole assy. !!
Feb 24, 2014 | Samsung HLP5085W 50" Rear Projection...
I have a 2005 toshiba 56hm195 with thin lines running through it
if retrace on screen maybe the capacitor is running defective.on the screen. consult that problem to Toshiba service center.
Jun 20, 2010 | Toshiba 56HM195 56" Projection HDTV
Multi colored vertical lines on my Sony LCD projection tv
Hello have the digital board replaced, Also the DMD board is known for failure on this model. DMD stands for Digital Mirror Device..
Oct 23, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bright Green spot
This could either be an issue with your DMD board or your Video board. While the TV is on, go the menu, if that green spot shows on the menu, the issue will be with the DMD board, but if it doesn't the issuw will be withe the Video board
Aug 03, 2009 | Panasonic PT-52DL10 52" Rear Projection...
Blue dots on screen.
Well it could be an issue with your video board or the dmd board, with the TV on, go to the menu. If those dots show on the menu, the issue will be with the dmd board, on the contrary it will be with the Video board
Aug 02, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Hls 5065 samsung rear projection tv
This could actually be an issue with either your DMD board or your Video board. With the TV on, select your menu, if the white dots are still there, the issue will be with the DMD board, but if they don't appear on the menu, the issue would be with the Video board.
Jul 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Feb 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Checking the color wheel on my DLP
Hello brandon b,
have you change the color wheel? what have you changed so far? Pleasenlet me know asap.
Best regards
circuitcity
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung hl-r4266w bottom black line
Your DMD board is now misaligned. It can happen when you changed the color wheel. All you have to do is pull up on your DMD board. I would use both hands, one on each corner of the DMD board and just a little at a time until you get it the way you want it. If you have a space at the top, then just push the DMD board down the same way.
Mar 21, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Green Screen
If set displays intermittent green outlines around images, check DVI cable attached to DMD board from digital board. Poor connections on the DVI jack on the DMD board can cause the intermittent symptom. Pull up slightly on the body of the DVI cable connector and check video. Replace DMD board as necessary.
Jan 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
HP AX325AA Notebook Portable LED Projector Companion with Expandable Tripod for PC Laptops Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
