Question about Frigidaire Ovens
Frigidaire digital wall oven mold CGEB27S7CB1 stop heat in the bottom element
The tope groil and fan work good, but the bottom (Bake) heat do not work
  • 1314 Answers
SOURCE: Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Posted on Jan 11, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
SOURCE: Bake element does not heat
After removing the racks, rack rails and the back plate I removed the 2 screws the hold the bake element. Lifting the front of the bake element up and carefully pulling the element out and gently moving the element so the connector clear the hole I was able to disconnect the wire. After testing for continuity with an ohm meter (non found) I determined the element need to be replaced. $37 and 45 minutes total.
Posted on May 29, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 13 Answers
    SOURCE: Neff U1721 bottom oven not heating fan & light are ok
    Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
    Posted on Jul 29, 2009
    My oven will not heat in any of the settings - bake, bake covection or broil. The fan and light work. Also, the self cleaning function worked blowing hot air for 3 hours
    Sounds like you need to change the heating element in the oven. comes out with two screws in the rear of oven. good luck
    Oct 21, 2017 | Ovens
    Thermador smw 272 not heating via bake or convection. Light and fan work as well as broil and clean (microwave fine too). If I switch from broil and then to bake after heated, it will hit right temp and...
    see if there is a bad solder connection on the bottom (underside) of the board just below one or more of the small black relay boxes. re-solder if you can or replace the whole board.
    Jan 04, 2015 | Thermador Ovens
    Have just moved from UK and we don't have broil and bake on our ovens - what do they mean/what's the difference as I've been cooking garlic bread on bake but it's taking twice as long to cook?
    The broil is the top element and the bake is the bottom element...so with broil you are heating from the top and with bake you are heating from the bottom...if your oven has a fan, turn that on with a bake setting and it will speed up the process..
    heatman101
    Apr 20, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
    Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
    Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
    The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Frigidale 10 years old stove bottom heating
    Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
    Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    My upper oven/ convection function on my dacor ecs230b will not heat
    Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
    Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
    Bottom Element Open Circuit & Fan Element not working
    No resistance in a bake element is a bad element. Replace it.
    Most fan come on with a rise in heat. No heat/no fan.
    Apr 08, 2009 | DeLonghi Ovens
    Kenmore electrical oven
    Trying to better define the problem....
    Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
    To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
    Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    59 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    ashburton
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
