Question about VAX Appliances Vacuums
Vax u90-p4p not picking up
Suction is fine from pipe but nothing when plug into floor suction unit
    Top Expert:
  • 14,553 Answers
You need to look for a blockage in the floor suction area.
Posted on Dec 03, 2012
  • 389 Answers
SOURCE: There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
Posted on Apr 21, 2009
  • 273 Answers
SOURCE: No suction
remove and wash all the filters
Posted on Jun 08, 2009
  • 58 Answers
SOURCE: decreased suction
Check your bag and your filters. replace if dirty or fairly full. IF the hose is old you also may want to replace the hose. an old worn out hose will loose a lot of airflow.
Posted on Jul 26, 2009
VacuumRepair
  • 438 Answers
SOURCE: Loss of bare floor pick up
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem sounds like the most probable to me, just because of the fact that you said you had just replaced the clutch, and therefore you had to remove the bottom sole plate. This is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icon in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum
Posted on Apr 05, 2010
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
Vax Air Reach U90 MA RE keeps shutting off when using
The wiring may be frayed. Suction trouble is standard; look for obstruction.
Jul 25, 2015 | Vax Vacuums
Upright Vax vacuum has no suction or hadly none from the base. Belt, motor, hose all working fine
yes turn it upside down and look real close at the area where dirt goes .they do plug up when too much big stuff gets in there .
Jun 15, 2015 | Vax Vacuums
Vax mach air reach suction problems
Thanks to N3FAR. It was very helpful, i have been callinv Vax and they are asking me to do all sorts of other things. Thanks you again
Dec 31, 2012 | Vacuums
Mannual for a vax 2000 vacum cleaner
Below can be found the downloadable user's manual for the Vax 2000 UR vacuum. If that's not it, check the manuals on the second link.
http://www.vax.co.uk/downloads/pdf/u90-vu-series_user_guide.pdf
http://www.vax.co.uk/support/resource_centre.php
Jan 09, 2011 | Vacuums
Vax turboforce not picking up
Hello Guest, Please check that your brushbar is turning, if isn't then your belt has broken, once replaced your machine should be fine.
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 11, 2010 | Vacuums
No suction when sweeping but plenty of suction from pipe
i guess u must ve mis inserted it...please see the user manual to fit it if ur new to it...... if no..then check the input hole for the dust...clean it with water pressure!!!! good luck!!!!!
Oct 22, 2009 | VAX Appliances Vax X5 Bagless Upright...
My Vax rapide is not sucking up water?
I had the same problem. Then I took off the brushbar (it's underneath at the front). It just pops off. Then it worked fine. I guess you only need it for long carpets.
Jul 02, 2009 | Vacuums
Vacuums Logo
110 people viewed this question
Top VAX Appliances Vacuums Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
