Televisions colors are not aligned
Rubbed tv all over with a small magnet it might have made letters better but the picture is a lot worse.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Convergence issue and a magnet will only make matters worse.
Google the model number with "problems"
Posted on Dec 03, 2012
  • 927 Answers
SOURCE: Color out of convergence.
Good Day;
Sounds like the CONVERGENCE IC has failed >STK-110 > 267P155010. TV only Uses one.
Good Luck, big IRISH.
Posted on Oct 01, 2008
  • 58 Answers
SOURCE: Samsung DLP Horizontal Lines and Scrambled Colors
i would like to see the pictures
thanks
Posted on Apr 18, 2009
johnnydiode
  • 647 Answers
SOURCE: TV comes on, various colors are not aligned
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Posted on Sep 27, 2009
Slinteriors
  • 8617 Answers
SOURCE: My Toshiba 55HX70 Rear Projection TV has suddenly
Replace both of the STK 392-110 ICs
Posted on Nov 22, 2009
SOURCE: tv picture is slightly blurry, looks like the 3
If the flash focus isn't doing anything you have bad convergence IC chips. This is a common problem with rear projection sets. The chips wear out from heat. You need new ones and they need to be replaced in pairs. The parts are not very expensive, the last set I did cost $38 for the pair on a Sony KP-57WS510. The repair requires some very tedious desoldering and soldering in the new ICs. If you have some experience with electronics and soldering it is not very hard. A shop will charge $300 and up for this repair. If you would like more details on this post a comment back here.
Posted on Dec 05, 2009
My televisons colors are not lined up
Magnet will only make matters worse---if a rca set Google the model number with "problems".
Dec 03, 2012 | Televison & Video
I have an RCA model D52W23 tv and the colors are out of line
Do not use magnet on or near this set---
This set is known for convergence problems where picture looks 3 d etc and this is caused by bad connections under and around the high voltage transformer in many cases.
First thing to do is look in menu to see if "Convergence" option is still there or missing----three small parts available as a kit exist to correct that if the option is missing (all are at same place around the high voltage transformer).
Set would have to be taken apart if you are able to check things there---if not most techs familiar with this set can deal with this in the home.
the connections and parts are all right where the high voltage transformer (called a flyback) is located.
typical flyback:
Tv works but picture color is off and its kinda dark looking there is no duel image so i know the color tubes are ok but there is a problem it almost looks like someone took a magnet to it
You have two problems, you have a convergence problem, the convergence board needs repair, and the other problem is the coolant needs change in the guns, (CRT's) and you are looking at 500 on repairs, you would be better off getting a new LCD.
Mar 02, 2011 | Philips 43P8341 43" Rear Projection...
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Everything in the picture is off. lots of pink and green involved and it droops in the middle at the top so the letters all curve down
This is very common for these types of TVs. Has it recently been moved or bumped? Or possibly exposed to a surge. - READ Warning below.
This is an issue with the color guns being out of alignment. This will require a TV expert to fix. The color guns are controlled by wire field coils wrapped around the CRT or main picture tube. Possibly the glue used to hold them in place may have let go some. I kinda know what to do, and I find it very difficult to do a good job of aligning the guns to produce a clear picture. Take it to a TV repair shop or have them come out to you would be better, because once aligned, it may shift again while being transported home.
WARNING. There are VERY high voltages in back of your set. In the 40 thousand volt range or more. Don't mess with it yourself unless you KNOW what you are doing. Don't guess.
For the money - I'd look at a new flat screen.. !!!!
Nov 09, 2010 | Sony KP-53V75 53" Rear Projection...
Height is small in aiwa tv model tv-se2130k, and how to go in service mode.
this is the conversion chip and vertical deflection chip that need to be replaced
service mode will only make the color alignment worse since the conversion chip is failing so it won't align properly
it will need that repair
Oct 16, 2008 | Televison & Video
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Rca wide screen tv
it sounds like your convergence alignment has shifted or you can adjust the screen and focus controls to see if they respond,if the colors or haze gets better or worse with the screen and focus adjustments ,loook at a cap in the screen circuit it should be 10mfd 250v cap the feeds the neck board,
Dec 22, 2007 | RCA 32F531T 32" TV
Color gone
you must have placed speakers around your tv. your tv tube has gotten magnetized.you will need a degaussing coil to remove those color stains if you do not have a coil call a tech to remove it for you.good luck.
Apr 23, 2007 | Samsung TXN2726 27" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
