Question about Snow Joe Sun Joe Lj600e Logger Joe 5 Ton 2 Hp Electric Log Splitter
Electric log splitter motor just hums then kicks the safety breaker
Plug it in. hit the power switch while lever arm. the motor just hums then kicks off. does not run. why
Masport log splitter how do you rewire a 7tonne pressure log splitter
Make sure the device is unplugged from the 240 VAC power source.
Connect the 240 VAC line and neutral wires to the momentary switch. Examine the motor wires to determine line and neutral.
This log splitter is equipped with a control system that requires to be operated by both hands of the user - Left hand controls the
hydraulic control lever while right hand controls the pushbutton
switch. The log splitter will freeze upon absence of either hand. Only
after both hands release the controls, the log pusher starts to return
backward to the starting position.
http://www.masport.co.nz/common/download/556964/
Hope this helped.
Apr 20, 2014 | Tools & Hardware - Others
Electric log splitter motor hums but won't run
suggest you get information on repairing log splitter, not dryer. have the same problem, and no replacement parts available. must be in the electrical, easiest would be capacitor, less the motor itself, take apart and see if windings burned, or smell electrical
Oct 13, 2012 | Dryers
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
Oct 08, 2012 | Heating & Cooling
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
My pump kicked the breaker, shutting off power to the heater and making the pipes freeze after letting it sit for awhile and hopefully unthawing the pipes i turned the pump back on it made a humming sound...
See if you can turn the impeller by hand...if you can then the motor start capacitor has probably bit the dust..this will throw a breaker if you leave it on too long...motor capacitors are available from appliance parts stores and some electrical supply warehouses
Jan 18, 2011 | Plumbing
Insinkerator has power but does not grind garbage. have hit reset button and turned allen screw at bottom. now i dont get a hum from the motor.
Is it hardwired or does it plug into an outlet? If it plugs in, check the outlet for power. Is a circuit breaker tripped? How do you know it has power if it doesn't even hum?
Oct 14, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Machine will not work
Any green wire is supposed to be connected to electrical ground (personal safety issue), but that would not keep the machine from working. Check the power socket with a working lamp. No power--find the right breaker in the house electrical panel, push the breaker off, then on, then recheck with the lamp. If you get power, then try the machine again. If it works, you are good to go, If the power goes dead again, either the breaker is in trouble and needs to be replaced or there is a heavy short circuit in the machine--usually a bad motor or it is trying to turn a frozen transmission. If that is the case, the motor will be locked, hum loudly, and eventually trip the breaker.
Aug 18, 2009 | Washing Machines
DRYER DOES NOT DO ANYTHING
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 02, 2009 | Maytag PYE2300AY Electric Dryer
Snow Joe Sun Joe Lj600e Logger Joe 5 Ton 2 Hp Electric Log Splitter Logo
102 people viewed this question
Top Snow Joe Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Snow Joe Heavy Machinery Expert? Answer questions, earn points and help others
