Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
Hi do you adjust the start pressure, and the cut off pressure
How do I adjust tank pressure
By letting air out.
Remove the pressure regulator plasic cover (usually one screw) and there will be 2 adjustment screws. One is for "cut-in" pressure (to start the compressor when the pressure drops below the set point), the other is for "cut-out" (to stop the compressor once that set point has been reached.
Oct 16, 2014 | Husky H1503tp
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
I adjusted both large and small springs on my pump switch trying to obtain cut out at 60 psig and cut in at 40 psig. Apparently, I have a pressure differential of 30 psig. It cuts in at 30 and cuts out at...
The large spring is for the cut in and cut off pressure, the smaller spring is for the differential in pressure, meaning it adjusts the lbs of pressure between cut in and cut off. Since you have adjusted the smaller spring you have a 30 psi differential instead of 20. To adjust turn the small spring counter clockwise 1 full turn or 360 degrees, then recheck the pressure differential (do not adjust the taller spring while doing this) You may have to repeat this two or three times. Once you have a 20 lb differential, then you can adjust the taller spring to get your cut in, cut out pressure. It works the same way. Clockwise for a higher pressure and counter clockwise for lower pressure. It's something you'll have to play with. It doesn't have to be exact, as long as it's close. Sometimes they are hard to get readjusted.
Jun 10, 2011 | Flotec TC2151 P2 Well Pump Pressure Switch
How do i adjust air pressure cut out
Square d recommends that the pressure switch be adjusted to specifications of the particular switch (which is sold in pressure ranges preset at the factory). The switch will be erratic it adjusted out of the factory setting range.
From Square D: (adjust the desired cut-in pressure first, then cut-out)
Cut-in: The large spring controls the cut-in pressure. To make adjustments, turn the nut clockwise (compressing the spring) to raise the cut-in point or counterclockwise to lower the point of cut-in.
Cut-out: The small spring is the differential adjustment and controls the cut-out pressure. To raise the cut-out pressure turn the small nut clockwise (more differential); to lower the cut-out pressure turn counterclockwise.
Sep 24, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Pressure switch adjustment problem...
I think I follow you... the adjuster over the large screw is used to set your tank pressure but also sets the cut-in/cut-off pressure. You have another regulator to control the pressure to and thru your hose but that doesn't insure that you won't exhaust the tanks supply and use more air than your pump can produce. It doesn't matter what pressure you set it at if your pump can't produce enough cubic feet per minute of air to keep up with your output. If your air use/output is within the pumps output, your idea will work just fine and you can set the hose regulator just below the cut-in pressure but Remember, even a little airbrush uses a lot of compressed air but sanders, grinders, sprayers and impacts use a Ton so don't try this without having somebody monitor the compressor periodically while you try it. It all depends on your air demand.
Apr 27, 2017 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
I HAVE A CRAFTSMAN 1 HP 12 GAL AIR COMPRESSOR THAT WILL ONLY BUILD 20 PSI THE COMPRESSOR ONLY HAS 1.5 HRS RUN TIME ANY SUGESTIONS
hi there, if the compressor built up a 20 psig and run at 1.5 hrs.then stop.check the pressure switch the differential pressure cut in and cut out limit.adjust the cut out to the corresponding cut out pressure you want but not exceed to the designed pressure tank..this will be done on adjusting cut out pressure screw mounted inside the pressure switch.follow the instruction on the manuals adjusting pressure switch.the run time correspond to the cut out limit of the pressure switch. rate my fix if your satisfied thank a lot.
Apr 20, 2010 | Air Tools & Compressors
The motor doesn't shut off when compressor reaches cut-out pressure, and doesn't start when tank pressure drop below cut-in pressure.
Hello. W/D here.
Normally, one setting or the other is the issue. When both are issues, one has to suspect mechanical damage. You can try to adjust the "quick and dirty" way:
Start the compressor and when you get to where you want it to cut off, pull the plug....really. Now, adjust the HP spring adjustment until the contacts break.
Then, open the drain on the tank, and let the pressure fall to where you want it to cut in. Close the valve. Adjust the LP adjustment until the contacts make.
There is also a differential pressure adjustment in some pressure switches; if you adjust this to narrow or widen your range, you must challenge and retest your upper and lower settings.
If you cannot manipulate the settings to open or close the contacts, the problem is probably mechanical. and the switch should be replaced. These are wierd little pieces of equipment; they are pneumatic, mechanical, and electrical, all at the same time. Sometimes you have to just hoist the flag and get a new one!
Good luck, and best regards, --W/D--
Aug 14, 2009 | Dewalt D55168 Heavy Duty 15 Gallon Heavy...
How to test a pressure sensor switch on a air compressor
Hi, W/D here.
To accurately test a switch, it has to be removed from the compressor and tested by raising the pressure and lowering it with air supplied from a known, good regulator. The trip pressures are then noted and adjusted.
The quick and dirty way of "getting close enough" is a little different. Start the compressor, and when it gets to your desired cutoff pressure, pull the plug. Adjust the HP spring untill the contacts trip out. Now, with the compressor still unplugged, drain the pressure off of the tank until you reach your desired cut in pressure, and close the valve. Adjust either the LP cut in or the differential pressure adjustment to set the cut in pressure. The contacts will pull in. If you adjust the cut in pressure with the diff pressure setting, the cut out pressure has to be challenged and set again. Whichever method you follow, you always need to check the upper and lower settings after each adjustment.
Best regards, --W/D--
Aug 13, 2009 | Dewalt D55153R Reconditioned 1.1 HP...
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
115 people viewed this question
Top Grundfos Garden Experts
john h
rhill2901
Level 1 Expert
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
