Colour problem have sony 29 inches tv the blue colour is low and the other red and green are high, please guide me how to set the colour
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Can you provide a model number as no 29 inch sets are projection.
Posted on Dec 03, 2012
  • 8457 Answers
SOURCE: Top left of unit, there is a blue green stripe the
Tv will get worse and will dies completely causes more damages to the other tv boards if continue using the tv this way.The tv have a problems known as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Jan 20, 2011
SOURCE: Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Posted on Dec 18, 2007
SOURCE: Sony 65 Inch Projection TV Color Red Green Separation
Same problem here. Nothing but problems with Sony. I will never buy another.
Posted on Feb 25, 2008
  • 2318 Answers
SOURCE: sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Posted on Jun 17, 2008
SOURCE: Sanyo CE26LD81B TV going from a red to green to blue screen
same arrrgggg
Posted on Jan 10, 2010
The scren shows only bue and green colouring and not 256 colouring ..how do i get 256 colouring?
Please check all the pin of the video cable, it sounds like the monitor is not getting the RED color signal due to bad cable or the video card is not sending RED signal. You also should set your PC video color to 16-bit depth.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 25, 2011 | Samsung 510N 15" Flat Panel LCD Monitor
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
XBox Audio Problems
The red, blue and green are ONLY the Video outputs, and connect colour to colour, now, there are Two other connections, again coulor to coulor, usually red & white, that hook up to the Stereo INPUT. So you need BOTH sets to work IE: The Video & Audio. Video: Blue, Red, Green. Audio: Red & White.
Jan 20, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony wega 28 inch colours wrong, circle on screen
It sounds that there is some magnet near by TV that is affecting picture tube. Please remove any extra speaker or any thing that has strong magnet inside, unplug TV for 20-30 minutes, replug back in, turn it ON, hope that will solve your TV problem.
Thanks.
Nov 16, 2009 | Sony WEGA KV-28HX15 28" TV
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Bush RFT TV
The picture tube of the tv has 3 color in CRT Red, Green, Blue. The red cathodeof tv set has no function, its either the resistor become higt resistance, that why u need a repairman to replace it.
Apr 10, 2008 | Televison & Video
Sony -kp65wv600
I got this TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
