I have an RCA model D52W23 tv and the colors are out of line
I tried rubbing it all over with a small magnet it looks like the the letters and numbers got a little better but the picture is worse?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Do not use magnet on or near this set---
This set is known for convergence problems where picture looks 3 d etc and this is caused by bad connections under and around the high voltage transformer in many cases.
First thing to do is look in menu to see if "Convergence" option is still there or missing----three small parts available as a kit exist to correct that if the option is missing (all are at same place around the high voltage transformer).
Set would have to be taken apart if you are able to check things there---if not most techs familiar with this set can deal with this in the home.
the connections and parts are all right where the high voltage transformer (called a flyback) is located.
typical flyback:
I have an RCA model D52W23 tv and the colors are o - 12_3_2012_7_08_31_pm.jpg
Posted on Dec 03, 2012
  • 65 Answers
SOURCE: RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Posted on Apr 09, 2009
ladywinn
  • 5138 Answers
SOURCE: bowed picture and color misalignment
Replace both STKS ICs Ck low ohm resistors 2.7ohms most of the time there will be 2 of them bad.
Posted on Jun 11, 2009
ladywinn
  • 5138 Answers
SOURCE: rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Posted on Sep 16, 2009
tlm931
  • 273 Answers
SOURCE: I have an RCA D52W23 TV convergence problem
bd pt no is 264103 check your local rca dist and servicers
Posted on Oct 24, 2009
Testimonial: "What a great site this is to get answers to questions very quickly. Thanks!!!"
SOURCE: tv picture is slightly blurry, looks like the 3
If the flash focus isn't doing anything you have bad convergence IC chips. This is a common problem with rear projection sets. The chips wear out from heat. You need new ones and they need to be replaced in pairs. The parts are not very expensive, the last set I did cost $38 for the pair on a Sony KP-57WS510. The repair requires some very tedious desoldering and soldering in the new ICs. If you have some experience with electronics and soldering it is not very hard. A shop will charge $300 and up for this repair. If you would like more details on this post a comment back here.
Posted on Dec 05, 2009
Televisions colors are not aligned
Convergence issue and a magnet will only make matters worse.
Google the model number with "problems"
Dec 03, 2012 | Televison & Video
My televisons colors are not lined up
Magnet will only make matters worse---if a rca set Google the model number with "problems".
TRYING TO FIND SONY D52W23 HDTV AND ALWAYS GET RCA. LOOKING FOR MANUAL
sonny or JVC do not make the D52W23 thats strictlly an RCA model number
Oct 19, 2011 | RCA D52W23 52" HDTV CRT TV
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps Partstore.com has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
Colors on the screen are scatttered, mean I can see the red, yellow and blue lines.
Go to menu then setup and see if you have convergence if not you have Blown Fuse FL231 it is located on right side of FBT flyback Transfomer there is 3 in a roll small brown looking caps But they are Fuses.06 it will be the one in the middle
Go to Partstore.com for part
Jun 01, 2010 | RCA D52W23 52" HDTV CRT TV
Color out of line,i had a problem with my tuner at but i replace that with a used one and this,i dont want to throw it away...
Go to menu, then setup ,do you see convergence? Listed in the menu? If not you have a Blowed Fuse FL231 on deflection board. There is 3 in a roll on the right hand side of FBT they are small brown looking caps rectrangler looking, they are fuses it will be the one in the middle.
Jan 10, 2010 | RCA D52W23 52" HDTV CRT TV
Rca d52w23 has distorted picture. it is shaped
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
