Question about Ariens 34 In. Zoom Series Riding Mower
Auger drive belt
Model #C950-52408-4 auger belt part#581264 to replace, what is the belt length?
Troy-bilt snowblower smokes when I try to engage auger. It’s the belt burning, but do I simply just replace the belt or is it something else that’s causing the belt to burn?
How old is it? Model? Can you move the auger single stage or augers 2 stage by hand when in neutral. Could be a ice jamb. or bad bearing. Do this with the unit NOT running. If it's a 2 stage take a 2X4 and insert in the chute
and try to wiggle or move the impeller. Bent impeller/auger? Maybe. check them visually.
Hope this helps.
Dec 26, 2017 | Troy-Bilt Garden
Toro Powershift 828 snow blower model #38570. What is the # & length of the auger belt.
The auger belt is part # 63-2964 and it is 1/2" x 42.5".
Feb 08, 2016 | Garden
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Auger on ariens 522 turns when not engaged
the drive shaft that connects to the auger may be stuck in gear or depending on the wear and age rusted shut. I would check that before doing anything.
Dec 29, 2012 | Garden
Yard Machine 5.2 HP snow blower Auger is not rotating not throughing / cutting snow.
Hi, The only thing I can think of is that your sheer pins are broken. Can you turn the auger by hand? If you can, look at the shaft that the auger is welded to, If you can look for bolts or holes on the auger center shaft, You will have to punch out anything that is left there. If that's the problem measure the diameter and length of the old bolts, or go to a shop that sells parts to get new sheer pins. You can also use ordinary bolts that will work well. Have you checked your belt to see if it is broken or has come off the pulley or if the belt tensionner is still on the belt or has come off not providing the right amount of tension so the belt does not slip in the pulleys and is able to turn the auger. Regards and good luck. I hope that is the problem and can be fixed easily and is cheap to do.
Jan 14, 2011 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
91 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
