Question about Canon PowerShot S51S Digital Camera
Camera screen remains black when I turn on shooting mode
When I turn on the camera in shooting mode and open the screen the screen remains black, though I can see through the viewfinder which I ordinarily could not when the screen was open and functioning.
I wonder if I somehow inadvertantly changed the screen. If I did I don't know how and don't know how to restore the usual function. I hope the camera is not broken.
  • Issue Jan 22, 2009
    When I turn the camera on I get a black screen most of the time. The ability to actually take a picture is there, but the picture is black. I cannot seem to figure out a logical way to consistently take pictures. Most of the time the camera comes up with a black screen. I have plenty of space on my memory, I have fresh batteries (I've even purchased different types to see if the more expensive Ultimate batteries work. I've even purchased rechargeable batteries. WHEN the camera works (which I do not seem to have an ounce of input on) the pictures are great. When it does not cooperate I get nothing but frustrated. PLEASE HELP!
  • Issue Feb 02, 2009
    We can see icons, if we press display the image will not show. We can view photos in our memory card but are unable to view or take new images (black only). Doesn't happens all the time.
    It’s like the lens inside is stuck closed even though the lens outside
    is extended.
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Posted on Feb 02, 2009
    New Friend:
  • 4 Answers
Maybe need change a new lcd, this is lcd shop:
http://www.flex-007.com
Posted on Nov 27, 2012
Camera still takes pictures but LCD screen remain black(lit, differnet from when screen is off) at all times. Batteries are fully charged.
Please make sure to check if the battery is fully charged. Second, check the menu option for battery saving mode and turn it off. If the battery is getting old and not charging fully anymore the priority of the camera is the shooting mode.
Feb 19, 2010 | Sony Cyber-shot W290 Digital Camera
Nikon coolpix S3- most of the screen is black on shooting mode
I am sorry to say that it sound like the display had been affected by being dropped. I shall do some more research and get back to you shortly
regards
Graeme
Mar 02, 2008 | Nikon Coolpix S3 Digital Camera
Mode switch has broken off and the camera screen says no image
it probably remained locked on the viewer and there are no images capture stored into the camera ..that's why it says that ....and it must be a way to restore the function of that button cause no matter if you lock it permanently into the the shooting mode its still a issue of getting pics out of it ....most cameras have to be on viewing mode when are plugged on the data cable ...but ..if you can open it and switch it on the mode that allow you to take pictures...you can always get the pictures from the SD card directly via an card reader ...adapter ( USB) that cost only a few dollars...
Aug 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Camera screen blacked out in shooting mode
No, dont fret. It sounds like you just accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batteries. You would then just use the optical viewfinder. To turn it back on, just press the DISP button one more time.
Jul 12, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Jul 11, 2017 | Nikon COOLPIX S5 Digital Camera
Screen Is Black
there are two possible problem of your camera..1 may be the iris is not opening..try to look at inside of the lens you should see the iris will open when you turn off and on the the camera at the camera mode..if the iris in opening the 2nd problem maybe is the image sensor is deffective..in this case you have bring it to the service center....
Aug 29, 2008 | Samsung 1.5MP High-Definition Digital...
After resetting to default settings, the shooting mode screen is black
Remove the batteries and put them back in. See if it restores the camera seettings.
Jul 19, 2008 | Canon PowerShot A95 Digital Camera
Black screen
Go to this link for UK. Near the top of the window, there is a search box. Type in 37383 and click the box right below it that is labeled "Search by Case ID". Then click the Search button. All information and instructions on the resulting page are applicable to the UK. There is a button at the bottom to contact Canon Tech Support.
Jun 14, 2008 | Canon PowerShot A70 Digital Camera
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
Sep 29, 2007 | Nikon Coolpix S3 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S51S Digital Camera Logo
488 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
