Question about Korg Cx3 61Key Modeled Combo Organ
Sound problem with KORG CX-3 Combo Organ
Left side of keyboard will generate sound. First key pressed on the right side of the keyboard generates sound, but after that there is no sound (neither left nor right side of keyboard will generate a sound). I have to cycle power to get back to square one. The right side key has an attack, but left side key does not.
  • Tim Hurd Dec 22, 2012
    I have looked at this for too long, and am pretty conviced this is a motherboard kind of problem.
    I have discovered that the keyboard is split electronically, and the left side keys are handled by the lower tone generator, and the right side by the upper tone generator. The issue seems to be that when the right side of the keyboard is used, that initial key is processed (in fact, you can presss other keys and while the first one is still pressed, but when I release any of the right side keys, the organ freezes, and no longer processes any other keys, left or right. Scoping out the serial bus between the lowe and upper tone generator DSPs, I see the data bus just go into a loop, continuously sending the same pattern. This is clearly the problem, but I can't figure out what could be causing it. I ran the on-board diagnostics and reset things to the factory state, but to no avail. I suspect it needs a new motherboard, but I haven't found any source for one. Does anyone have any additional information or suggestions? Thanks.
2 Suggested Answers
  • 5603 Answers
SOURCE: My Korg CX-3 Combo Organ
From the user manual troubleshooting:
No sound
• Are the other devices or headphones connected
correctly?
Check the connections. ........................................ (see p.6)
• Is the power of your amp or mixer turned on?
• Is the [MASTER LEVEL] knob raised?
• Is the Global mode Group 4 "MIDI Local" parameter
turned On?
Check the setting of this parameter.
• Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
Posted on Mar 09, 2011
Old korg cx-3 intonation off with standard piano tune
if it's the old analog version, there should be a tuning knob in the group of controls on the left hand side by the drawbars.
Dec 27, 2016 | Korg Music
KORG CX-3Combo Organ
DSP is Digital Signal Processor.\\
That is electronics and would have to be serviced by the company or authorized service centre
Sep 17, 2016 | Music
How can we off the touch of korg X5D keyboard?
If you mean is to OFF the key touch,this is the steps :
  • Press GLOBAL.
  • Press PAGE+ . Find menu VELOCITY CURVE. To select parameter,use left/right arrow buttons(move cursor).
  • Set the value to 0,by press up/YES or down/NO buttons, or use VALUE slider.
Jul 05, 2015 | Korg Music
I have a Korg Pa800 and it now has 1 key sounds louder than the others, I dont know if I had pressed something wrong. Please help
hi Peter
try to change to organ sound if is not happened the problem is the rubber contact under the keyboard (clean o change the rubber)
Sep 01, 2013 | Korg Pa800 61-Key Professional Arranger...
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
FACTORY RESET ON KORG pa50SD
i use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Apr 02, 2012 | Korg Pa50 Professional Arranger Keyboard...
My Korg CX-3 MIDI configuration tests for upgrading to Version 2 have failed numerous times. However, I am confident that it is not my MIDI interface. All Global settings and parameters seem to be...
If this is a flash upgrade to the unit be VERY careful as a failed upload can leave unit dead. They usually have pretty tight checks to prevent an error from killing the unit during the upload. For certain music products I have found that I had to upload an in between version first that was available before uploading the latest current version.
Jul 29, 2011 | Korg Cx3 61Key Modeled Combo Organ
My Korg CX-3 Combo Organ turns on, but when it's plugged in to an amplifier, I don't hear anything and it doesn't generate any sounds except for a clicking noise when hitting the key. I hope you can help...
No sound
correctly?
turned On?
Mar 08, 2011 | Korg Cx3 61Key Modeled Combo Organ
I have a1980 Korg CX3. Last night at the gig It started to make noice that sounded like all the keys were being pushed down at once. It did npot matter if I was in a preset or using the drawbars. Any...
This is likely a power supply problem. It is important that all interconnected equipment be powered by the same receptacle OR source or isolation such as DI's be used for system safety.
Jan 30, 2011 | Korg Cx3 61Key Modeled Combo Organ
Korg Cx3 61Key Modeled Combo Organ Logo
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
