Question about Dell Latitude D600 Notebook
How do i enable the configure password of my dell d600 laptop
Forgotten config password
    New Friend:
Remove the pile and install it again
Posted on Dec 03, 2012
athulnair
  • 101 Answers
SOURCE: I have forgotten my laptop bios password
  • Just remove the BIOS battery from your system.
  • Then reinsert the battery.
  • Password of BIOS will be reset.
  • That is the way to reset the password.
-rate if it helped you.
Posted on Apr 07, 2010
  • 30 Answers
SOURCE: Latitude c400 "configure password enabled"
You could try to contact the owner who had it before you, if you know them. Or you will have to pay for a hack.
Good luck
Posted on Jan 19, 2009
  • 16 Answers
SOURCE: Forgotton Configuration Passwordd of Dell Latitude D600
Unfortunately the only way to do this is by removing your battery from the mother board.
When i am refering to the battery , i mean not only the normal battery which you can un hook and rehook again pretty easily but the one from the interiors of the laptop its called a CMOS battery. Befefore you go opening up the laptop physically make note of the BIOS settings, as these changes will be wipped out when you remove the CMOS battery
Refer to the dell documentation that may have come with the laptop as to how to open the laptop physically.
You can also try if you can override the BIOS by upgrading it from the Dell website. (Although this may not work)
Best of luck
ksb
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: Conection to TV using S-video on Dell D600
install the ati omega drivers for your OS from http://www.omegadrivers.net/ati.php and follow the readme file. Note that although you have a 7-pin s video output, only use a 4 pin cable. After installing the drivers per the instructions in the readme file and rebooting, on the screen with the outputs where you've seen TV as a greyed out option, you now have the option to force TV output at the bottom... That was the missing feature that ATI's drivers did not support. You should be good to go from there. Additionally, some people suggest making sure the svideo cable is connected from the laptop to the TV when you boot up.
Posted on Jul 15, 2009
  • 192 Answers
SOURCE: how to remove config password on dell latitude
There are several ways to reset the password on the D600 laptop. Some require special eeprom reading equipment. However, there are some who've stumbled upon a "paper-clip" method that involves shorting the eeprom while booting the laptop. There are two of these methods in general.
One requires removing the entire cover of the laptop, then creating the mentioned short-circuit, then booting the laptop. This site: http://www.weeklygripe.co.uk/a709.asp#guide shows the process step-by-step with high-quality photos. If you are at all handy with a screwdriver, this can be done in about a half-hour and you are ready to go.
If you are a bit less handy, there is a one-panel removal trick that this guy has posted on YouTube: http://www.youtube.com/watch?v=hx5HBHgv8T8&NR=1&feature=fvwp
The preferred method is to contact Dell. However, Dell will only help you if they can verify the chain of ownership of the laptop. This involves the original owner having thought to contact Dell and let them know that you are now the new owner. This can still be done now, if that owner is available and willing.
Also, there are companies that specialize in password recovery. Nearly every one of them will either get you the current password or reset it for you. Some also sell software to do the same. Since they are all nearly as effective as the other, you should really shop around for price if you choose to go this route.
Choose a method, be careful, and you will have your laptop unlocked in no time.
I hope this helps
Posted on Aug 02, 2009
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
Tip
Cisco 3925 Router Password Recovery
TheCisco 3925 router is part of a family of networking equipment produced byCisco, which has been a network equipment giant for many years. Used 3925routers are available on the Internet at reasonable prices, so acquiring one isnot difficult. However, if the password is unknown or lost, reconfiguration isimpossible until the password is reset or recovered.
Cisco has built in aprocedure for rescuing lost or forgotten passwords or entering new passwords.
ThingsYou'll Need: Serial to RJ-45 cable;Terminal emulation software
Instructions
1.Connect your computer to the router with the blue serial-to-RJ-45 cable thatcame with the router.
The 9-pin D-shell end connects to your computer's serialport, while the RJ-45 end connects to the console jack on the router.
The RJ-45end resembles a slightly larger telephone jack connector.
2.Turn on your computer and establish a terminal session to the 3925. You can use any terminal emulator, and many are freely available on the Internet.
Configure the session settings as follows:9600baud8data bitsNoparity1stop nonflowering controllable router's power cable into an electrical outlet, and as the 3925 boots, you should see the Cisco boot messages.
If you don't see any output on your computer's terminal session, check your settings on the session and restart itif necessary.
Press "Break" within 30 seconds of powering on the router to enter rommon (rom monitor) mode.
3.Type "confreg 0x2142" and press "Enter" at the "rommon1>" prompt. This will cause the router to boot from its internal flashmemory without loading the configuration into memory.
At the following"rommon 2>" prompt, type "reset" and press"Enter."
This will cause the router to reload and ignore thepreviously saved configuration file.
4.Respond "no" and press "Enter" when prompted for responsesto enter the initial dialog or basic management setup.
Type "enable"and press "Enter" at the following "Router>" prompt.This will put you into enable mode and display the "Router#" prompts.Copy the non-volatile memory into memory with the "copy start up-config running-config" command, followed by the "Enter" key. Type"sho run" at the prompt and press "Enter" to display the current configuration, including the passwords, some of which may be encrypted.
5.Type "config t" at the prompt and press "Enter." At the"Router(config)#" prompt, type "enable secret <pswd>"-- where "pswd" is the password -- and press "Enter." Atthis point, your enable password is reset. Press "Ctrl" +"z" to return to the "Router#" prompt.
6.Type "config t" at the "Router#" prompts and presses"Enter." At the "Router(config)#" prompt, type"config-register 0x02102" and press "Enter" to reset theboot register to its normal setting. Press "Ctrl" + "z" toleave configuration mode. Type "copy running-config startup-config"and press "Enter" to save your changes. Reboot the router and youshould be able to login with your password.
on Sep 05, 2011 | Computers & Internet
Tell me how to enable dell latitude d600 setup password
go to setup when booting usually del key or f key in bios you will see security section you can add passwords for booting and to enter windows
Feb 02, 2011 | Dell Latitude D600 Notebook
How do i disable the configure password of my dell d600 laptop
For your Dell D600 laptop the configured password can be disabled easily by you only if u know the password of the BIOS pasword.
if YES.
simply enter the BiOS setup , then Securities, there after Enter the Disable Password.
Dec 22, 2010 | Dell Latitude D600 Notebook
Hi i have 1841 router what is the default user name password for this i tryed with user name passowrd as cisco but is saying that no user cisco pls help me
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Jul 02, 2010 | Cisco (1841) Router (cisco1841)
Apr 07, 2010 | Dell Latitude D600 Notebook
How do i enable the setup configuration in the
Hi:
as your Dell boots up, you need to start hitting the F1 key to enter setup, and once you are in, you can tab thru the various pages of settings. When you are done, hit F10 to save and exit.
Nov 06, 2009 | Dell Latitude D600 Notebook
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
FORGOTTEN ADMINISTRATOR'S CONFIGURATION PASSWORD IN SET-UP(F-2)
the only way to reset a system password is to contact dell support. they have a tool to generate a master reset password specific to the service tag of your computer. :) try calling this number 1800 6228965
Oct 05, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Dell Latitude D600 Notebook Logo
65 people viewed this question
Alun Cox
