Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
Installed sink faucet, 4309134, part #3 will not hold tight so part #2, Acrylic handle turns 360 degrees, where can I obtain a replacement for part #3?
  • Peter J. Boulware Dec 05, 2012
    The manufactor is sending a new part #3
Which is the good Commercial Hot and Cold Sink Faucet?
Comllenhas been producing high-grade commercial kitchen appliances from the beginning, and it never stopped seeking glory. Its products are praised by the users who think that the company focuses on performance and durability which most commercial kitchen owners want.
Especially the Commercial Kitchen Sink Faucets are the highlights of the company. One of its unique commercial faucets is the Comllen Kitchen Faucet.
The ease of installation is commendable as well as the single handle control. You can use one handle to control the water flow and the water temperature. The handle makes your work a lot easier when you have your other hand occupied. The stainless design along with the brushed nickel finish is also noteworthy. The head can be rotated at a 360-degree angle allowing you to have options while working. It is a well-rounded product.
The Feature and Specification of Comllen sink faucet are given below:
Feature Analysis
360 Degree Head RotationThe head of the faucet can be tilted to 360° positions. So, you can get the water stream in any direction you want to.
One Handle ControlIt has a simple one handle operation. You can control the water flow as well as the temperature with this one handle.
Dripping Free TechnologyIn our Comllen Commercial Hot and Cold Sink Faucet review, we feel delighted to mention this unique dripping free system that reduces water wastage while helping to reduce energy bills.
Easy InstallationThe faucet can be mounted and installed pretty easily. It comes with a one-hole mounting feature which makes it easy for the user to install this faucet.
Specifications
  • Dimensions (L x W x H):15.8 x 7.5 x 2.1 inches
  • Adjusted Weight:2.85 Pounds
  • Colors Options Available:Brushed Nickel
  • Mount Options:Surface Mounting
  • Body Material:Brass
  • Handle Type:Single Handle
  • Body Design:Contemporary
  • Coating Medium of the Faucet:Brushed Nickel
  • Warranty Provided:Limited Lifetime
Mar 20, 2018 | Plumbing
Moen 7100
the internal components of a single handle Moen require delicate alignment and accuracy. Since a full circle is 360 degrees, I would recommend replacing the entire faucet with a more conventional two handle style.
Aug 27, 2014 | Moen Plumbing
Handle will not turn water off
single cartridge? pull old one, flush some water through empty valve then install new cartridge. once installed, make sure the horseshoe clip is properly inserted to keep the stem in. once the clip is in right, there is a chrome tube with a ridge that slides over the barrel and the clip. the ridge acts as the stop for the handle. also make sure there are stops inside back of handle to hit the ridge on the chrome tube. the plastic inside the handle may break off allowing the handle to spin. the stem unit/cart may also be installed 180 degrees out of place. pull the lock clip and use the remover tool that came with new cart to rotate it 180 degrees with water supply turned off.
Jun 17, 2013 | Moen & One Handle Tub & Shower Faucet
Base of single handle kitchen faucet is loose where it sits on the counter
there should be 2 plastic nuts under the sink that hold the fixture tight to the sink. if they are tight allready try to install washers and see if that helps. right is tight. left is loose.
Jun 08, 2012 | Delta Faucet Plumbing
Faucet loose in side / when you move handle hot to cold lines under sink move with it.
If you installed the faucet you need to use a basin wrench to make the nuts tighter under the sink and this will stop the movement. Some fauect have a large nut with two set screws on each side. Then you just make the nut hand tight and then take a screw driver and then make those two set screws tight and then the inside will pull tight
Best of luck
RJ
Sep 07, 2011 | Danze Plumbing
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    My cold handle on a montecello faucet turns freely, however, nothing happins I have no cold water. What do I do?
    First check that the handle is tight. If yes take the handle off and turn on the water buy turning the stem without the handle if you still do not have water remove the stem and cartridge and see if you have water if yes clean or just replace the cartridge. If the faucet in old replace both.
    Mar 15, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    Grohe faucet handle doesn't retract
    Ok well that is probably the install then.  there is a brass ring under the sink that is holding the faucet tight to the sink.  this has 2 water lines that feed the faucet and the line to your spout.  if the copper lines are not pushed apart enough than it will rub one the line with the weight and make it hard to move up and down. you need to get under it with a flash light and move these lines apart.  The worst  would be that when the faucet was installed the hole was not big enough and that is what it is hitting.  So I hope this help you .
    Jun 23, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
    Wobbly faucet on new elkay sink
    this faucet comes with diffrent hold downs for diffrent sinks on is wider for stainless sinks the other is smaller for granite or corian sinks, it sounds like your plumber might have put the wrond spacer under the facet where it mounts to the sink,, it doesn't matter the sink or the faucet they all come with proper adapters, and I do know that moen and delta have them in the box with the faucet,,, good luck with yo people, this faucet of yours even comes with the plastic tool to put the faucet in because it has a long shank with threads on it and is hard to get a wrench on
    Jun 07, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
    44 people viewed this question
    Top Ace Hardware Home Experts
    guitar zan
    Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
