Question about Sony ICF-2010 AM/FM/SW Radio
Sony 2010 while tuning chopper circuit cuts out, and eventually locks system above 7.5 Mhz, have to reboot the computer to restore it
As I tune higher in frequency the frequency starts to jump in larger and larger increments until it locks
4 Suggested Answers
LVT7857
  • 116 Answers
SOURCE: SONY CDX-SW200 only tunes into odd frequencies?
Not unless he unit is capable. I know that Cadence made their decks with this feature, and I haven't seen anyone else as of a year ago.
Posted on Jan 28, 2009
kb8dns
  • 494 Answers
SOURCE: Sony ICF ICF 77 Receiver has intermittent Low
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Posted on Feb 06, 2012
send to a service of sony repairs mail: (medina604@gmail.com) in north Spain
Posted on May 06, 2017
Cricut explore one. Downloaded program,but get error message,wont install
Frustrated!!! [Driver installation problems][Resolved] - Make The ...
forum.make-the-cut.com/.../frustrated-driver-installation-problems-resol...
May 11, 2010 - 29 posts - ‎10 authors
I cannot get the Cricut firmaware to update. ... I just got a new computer with Windows 7, I tried to cut with the cricut but I get two error messages. RESOLVED Problem getting computer to recognize Cricut
Dec 15, 2010
RESOLVED!!!Help Sending Cuts to Cricut
Jul 24, 2010
Cricut Error: Unable to load drivers
Jan 28, 2010
cannot get program to cut
Jan 14, 2010
More results from forum.make-the-cut.com
Dec 28, 2015 | Computers & Internet
Tuning problem KV-21CL10
try to setting your tv in menu! and you can see the menu has air cable tv mode then select the ADD or ERASE mode! you select all channels to ADD mode! or you can auto search the program!
Oct 06, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Apple I POD is disabled message try again in 22 Million minutes, will not reboot
Plug your iPod into iTunes, click on your device and click the "Restore" button :D
Mar 24, 2014 | Apple Mini IPod
Had power cut cant open i tunes
Re-install the iTunes.
Go to Start/Control Panel/Uninstall a program/Select iTunes/Click on Uninstall
Restart your computer
Go to Apple.com and click on iTunes
Download and install them.
I would also recommend you to buy a special device which helps to prevent your computer from turning off when there are power schortages.
Mar 18, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I reset my ipod touch but the screen appear with itunes icon and usb connector
The OS (operating system) of your ipod is corrupt for one reason or the other. The ipod won't boot or start because the start-up file or necessary files needed to boot up the ipod are corrupt.
The solution to the problem is to re-installing the OS (operating system) of the ipod by restoring the ipod. To achieve this, you will be needs a USB cord for your ipod model and i-tunes installed on your computer. Once you have i-tunes installed on your computer and a USB cord, then the job will be done and your ipod will be back to normal again.
If you don't have i-tunes installed on your computer, go to www.apple.com
Click on i-tunes and download i-tunes for free, then install it on your computer. After installing and downloading i-tunes, follow the below steps:
Run the i-tune program on your computer
Connect the USB to your I-pod
Connect the other end to your computer
Wait a while for the computer to recognize and install the ipod, then read and follow instructions on the i-tune. It will ask you to restore your ipod.
But if the i-tunes doesn't recognize the ipod via your PC, press and hold the Power button and the home button for 5 to 10 seconds. Leave the power button and keep pressing the home button or vice-ver-sa till the restore option comes up.
Click on restore and follow instructions thereafter.
After the whole restore process, your i-pod will be back to normal again.
Note: Make sure you back up your ipod if the files on it are very important to you. Start by syncing your iPod with your computer. When you do this, the iPod management screen will appear. Midway down that screen there's a button that reads "Restore."
Please let me know if you need further assistance.
Good luck.
Jan 16, 2012 | Apple Audio Players & Recorders
Audio and picture go dead red light blinks 7 times
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
Jan 24, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Dell Dimension 8300 boots up but locks up /freezes in any user area. It doesn't seem to be a hardware issue. System restore failed to resolve the problem. Prior to problem I accepted Java 6 update 18...
login via safe mode. hen run msconfig, deselect everything. reboot, then uninstall the latest pieces of software. run msconfig restore full services etc. reboot and repeat unitl resolved!
Also look at this blog post, it suggests a good tool to help speed up your computer, but also can be used to resolve issues.
http://simontodd.com/2010/01/how-to-speed-up-your-computer-for-free/
Thanks
Feb 28, 2010 | Dell Dimension 8300 PC Desktop
KENWOOD R2000 POLICE SCANNER
The R2000 is a shortwave receiver, not a Police scanner, covering 100 KHz to 29.999 MHz.
There was a converter available (VC10) that connects to the back of the unit that will allow tuning between 118 MHz to 174 MHz.
http://www.rffun.com/catalog/commrxvr/r2000.html
Please let me know if I can be of futher assistance to you.
- Jim
Mar 07, 2008 | Radio Communications
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Sony ICF-2010 AM/FM/SW Radio Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
