Question about Drills
There is'nt a manual or parts breakdown on my vectrax drill press #00492108
Would like to know what motor and on/off switch goes with tis drill press
  • 58 Answers
SOURCE: parts manual
hi a bit tricky this one as far as i am aware ram no longer exist your best bet might be to try a want it now post on e bay someone somewhere is bound to have one ,even if you carn't get a complete manual you might be able to photocopy the pages you need best of luck silk090
Posted on Jan 14, 2009
SOURCE: I have a Buffalo No. 15 floor model drill press
http://owwm.com/mfgIndex/pubdetail.aspx?id=1268
There are other manuals/parts lists for that press on the same site.
Good luck with the restoration!
Posted on Jun 27, 2009
  • 4088 Answers
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
Posted on Aug 23, 2009
  • 302 Answers
SOURCE: I have a old stand up drill press ss 1 944 with a
Walker - turner has been out of business for a long time. You should be able to move the motor mount toward the spindle to loosen the belt and change without removing the pulley. hope this helps you.
Posted on Oct 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need to know the price for this part No.905610
can you describe the part, the other part number you furnished are superseded with replacement parts and I can't find this one listed, let me know and I will try and help
Posted on Mar 13, 2010
Guardian Power Drill Press BDM-58-12S Manual
Try Googling (Guardian)(BDM-58-12S)(manual) without parens.
Apr 05, 2018 | Drills
Makita 4010 roto hammer, stuck in drill mode, cannot switch to hammer.
Here is the owners manual, page 5 and 6 shows how to switch modes. If it won't switch the you have some internal damage. The second manual is a parts breakdown. Concentrate on parts 63-79, and 160 http://powertool.manualsonline.com/manuals/mfg/makita/hr4001c_hr4010c_hr4011c.html?p=5 https://www.ereplacementparts.com/makita-hr4010c-rotary-hammer-parts-c-97_380_3717.html
Mar 15, 2015 | Makita Drills
DELTA 17-924 Mortising attachment for chisel bits
Go to the Dewalt Servicenet site (they own Delta) at http://servicenet.dewalt.com/. Put your model number, 17-924, in the parts search box (with the dash, otherwise it can't find it) and you'll go to a page where you can view or download the parts breakdown and instruction manual.
Sep 06, 2012 | Delta 17-924 Mortising Attachment with 1/4...
Need manual for Black & Decker drill/driver no. 9021
Go to the Dewalt ServiceNet website at http://servicenet.dewalt.com/. Put your model number in the parts search box and you'll be able to view or download the manual and parts breakdown.
Aug 30, 2012 | Black & Decker Drills
Manual for delta 17-924
Go to the Dewalt service website at http://servicenet.dewalt.com/ and put your model number in the Find Parts searchbox. You'll be able to view or download the parts breakdown, instructions manual and instructions on how to build an auxilary board.
Aug 02, 2012 | Delta 17 924 Mortising Attachment
How do i know if i have a faulty switch in my drill
if its electric each time you trigger the button the motor should spark
if its cordless drill and it makes a clicking nose and does'nt work then the motor is dead.
Jul 26, 2012 | Drills
When i press power botton half way works when i press full sometime work sometime don't
the switch is bad and would need replaced. MAKE note of the wiring if you attempt to do this yourself. Get back to me with the brand and model number and I will try and find you a parts source and breakdown.
Jan 24, 2012 | Drills
Motor operates but drill has no power forward, only reverse.
you have a problem with the switch or the reversing lever. If you go to take it apart use caution that you do not disassemble the gear mechanism, you can find a breakdown and buy parts from them direct or they also have a locator at makitausa.com. I would look at the breakdown before trying to disassemble.
Aug 01, 2011 | Makita 8443DWDE Factory Reconditioned 18V...
I need a fine threaded screw that goes into the bottom of the drive that holds the drill bit chuch in place on my radial drill press model # 149.21334. I don't have a manual or a part number. Thanks.
this chuck doesn't have a chuck retaining screw, it is a taper fit. Go to Managemyhome.com and type in your model number adding a zero after the last 4 and you can download a breakdown/manual for this unit and it shows how to reinstall the drill chuck. Let me know if you need more assistance and if I have helped you would you please rate this response accordingly and thank you.
Feb 13, 2010 | Craftsman Drills
Delta Variable speed drill press will not spin belt freely
I would go to Dewaltservicenet.com and you can download a breakdown and also user manual for this tool with information about the set up and belt assembly, the breakdown would show you how everything is supposed to go in the pulley section. L et me know if you need further help
Oct 07, 2009 | Delta Drills
Drills Logo
102 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
