Question about Maytag Neptune MDG5500AW Gas Dryer
My dryer (neptune original series) is making a scraping sound. The last time this happened, the bolts that hold the tumbler in place were loose and rubbing against the top of the dryer. I need to know how to get the top open so I can tighten the bolts
  • peepawhuff Mar 09, 2009
    maytag MDE3000AYW dryer needs front drum felt replaced. Have the felt, need to install. Help!!!
    New Friend:
  • 88 Answers
First take out the 2 hinge screws then the other 2 across from the hinge pull the panel down. then you will see a 5/16 screw holding a hook that is holding the top down. there is one on each side. let me know what u find.
Posted on Jan 11, 2009
When turned on dryer tumbler makes a metal on metal scraping sound?
Most dryers glide on felt. Either the felt has worn out (not very likely) or something has gotten between the drum and the felt. Could be anything from loose change to jewelry...anything that made it into the dryer from a pocket
Feb 13, 2016 | Dryers
The drum of my dryer is scraping against the outer wall and making a horrible noise
has the small wheels that hold the drum in place while it is running or a bolt somewhere has come loose causing this to happen
Mar 04, 2011 | Bosch Nexxt 500 Dryer
My Maytag Neptune is making a banging sound while it dries. The motor was just replaced last year. Could something be loose or is it more serious than that?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 12, 2011 | Maytag MDE2400AYW Neptune Electric Dryer
My Neptune is very loud during agitation. Any
sorry about that to me if also very loud on the spin cyc and is a front load the tub bearing and then your talking a major overhaul with high cost involved
Aug 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Maytag neptune model MDE5500AYW loose tumbler in drum
I had the same problem but it's the FRONT Panel you need to remove. Before you start, unplug the thing first. BTW I did the whole proceedure in 10 minutes using an electric screwdiver / philips bit and a socket set with an 8mm socket with my leg in a cast. You can do better, I'm confident!
Two 8mm hex head bolts hold each fin on the drum. They can be tightened. You need to open the dryer front since they bolt from the outside of the drum. To open the dryer front you first take the door off by removing the two philips head screws, then slightly lift the door and pull toward you (the door hinges have little hooks on the end that inserts into the slots (this little design keeps the door from falling off during removal and install-nice). Then remove the two philips screws on the other side of the door opening (opposite the door hinges). These screws hold two plastic brackets (be sure to see how they are aligned before you remove them so you know how they go back on.
Now the front frame panel looks like an "H" . Grab the top two arms of the 'H" and give a quick pull. The top arms of the 'H" will come loose. The bottom part is held by a couple of clips, just pull up and the front panel comes off.
You will be able to spin the drum until the hex bolts for the fin(s) in question are visable / reachable from the right side (just above the heater unit-hope you unplugged the dryer earlier). I tightened it using an 8 mm socket.
Now reverse your steps: put the front panel back on the bottom clips and snap the top "H" arms back in place. Reinstall the plastic clips / screws and then put the door back on.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
REPLACING BELT
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Scraping noise
hi there,
the scraping could be the tumbler itself. please check the belt around the tumber and make sure that it's not worn.
thanks
Sep 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer
the top cover is fastened by spring like tabs on the machine rear. the front edge of the top merely clips to the front panel. the top needs to be removed to gain access to the bolts that hold the front panel on. these are inside the top corners of the machine. once these are out, the front cover should just pull up to remove. there may be a light connection and the door switch wires here too. then you can get to the screws that hold the baffles in place.
Dec 27, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
140 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
