Question about Craftsman Sears Snow Thrower Manual Model No 536.881651
Craftsman snow thrower 536.881651 runs only on choke
Machine will only run smoothly when the choke is engaged. once i switch it off, the idle becomes very rough and eventually stalls
  • 168 Answers
SOURCE: Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Posted on Aug 02, 2009
  • 430 Answers
SOURCE: CRAFTSMAN 5 hp 24 SNOW THROWER, WONT STAY RUNNING
rebuild the carb.
Posted on Nov 30, 2009
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
  • 4088 Answers
SOURCE: craftmans snow thrower model 247.887900
Remove the fuel line from the carburetor to check the fuel flow from it--there should be a thin stream of fuel flowing out--if it just drips, something is plugging the line, fuel filter, or shutoff valve. If it seems ok, then the float and needle valve in the carburetor bowl may not be allowing fuel to flow into the carburetor. It is probably necessary to remove the carburetor to check these components. Make sure to have fresh fuel in the tank. Hope this helps!
Posted on Jan 23, 2011
  • 36 Answers
SOURCE: Will a snow thrower 42" Mod. no. 486.248392
As long as your deck mounts match up then you should be good to go. You might have to change to a different sized belt though. Other than that everything should be fine.
Posted on Feb 08, 2011
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
Hello I have a craftsman 123cc single stage 4 cycle snow thrower. . Motor runs great with a little choke. When I put choke off it runs high and low. The spring linkages are moving back and forth
pull the carby and clean out the jets and passages
the carby cannot produce a constant air/f;ow mixture unless the choke is on and the governor is having difficulty keeping the engine speed constant
Oct 19, 2015 | Garden
My craftsman snow thrower runs for about15 minutes before it requires more chock until it finally cannot run. Why is this happening
First i would check engine compression. It will change once it gets hot and cause you to use more choke until finaly it wont run.and if that is okay i would rebuild the carburator. A rule i use in my shop is to always check compression first then go from there.
Dec 13, 2014 | Craftsman Garden
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Craftsman Sears Snow Thrower Manual Model No 536.881651 Logo
116 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
