Question about Ricoh Aficio 450 Copier
SC 400 I HAVE PROBLEM IN RICOH AF 4506 GIVEING CODE 400 I HAVE CHAG T BELT AND AROND T BELT
  • Anonymous Mar 13, 2014
    what is ricoh sc 400
  • 162 Answers
Check the connections of the transfer belt unit can be a false contact.
This code disappears when shut off and on the copier.
Posted on Sep 13, 2009
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; The error code you post out, it's means "transfer belt bias problem" that you have go to high voltage board ,I/O board or main board, before we go, why don't try make a reset;
1, press "clear mode" key, then enter 107 then press and hold down "clear/stop"..
2, turn power off and on.
Posted on Jan 11, 2009
Ricoh sp C221SF Error code Sc 400
The board that controls it. Probably the IOB. Typically, the code is cause by a dirty ID sensor.
Oct 04, 2014 | Ricoh SP C221SF Aficio Printer
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
ERROR SC410 ON AFICIO 4506.. ANY HELP APPRECIATED adanquah@gmail.com
I know an SC 411 means this:
SC411: Separation bias leak error
-Definition- [B]
A separation bias leak signal is detected.
- Possible causes -
• High voltage supply board defective
• Poor connection of the PCU
• Discharge plate defective
Usually a 410 would be in the same ballpark on a Ricoh computer. Unfortunately I don't have the service manuals for 4500 series machines. If you can get a hold of a Ricoh tech in your area, it would be a good idea to rest the power supply and check the pcu as well.
Feb 18, 2009 | Ricoh 4506 Copier
Print problem With Ricoh 4506.
First of all E-310-285522 is not an error code.It is the Fiery printer number.
Looks like you have enabled password for this copier and ticked accidentally the "password for printing".
May 01, 2008 | Ricoh 4506 Copier
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
Error code sc 422
422 D PCC leak
- Timing & Condition -
When the current leak is detected
for 2 seconds, leak detection
starts 1 second after the PCC
turns on. The leak signal is
monitored twice at 1-second
intervals. When the leak condition
is detected twice continuously,
this SC is displayed.
1. Check if the PCC unit is properly installed.
2. Replace the corona wire if it is broken.
3. Check if the connectors on the terminal and
high voltage supply board (T1, PCC)
are
properly connected and if the cables are
damaged.
4. Clean the receptacle.
5. Replace the high voltage supply board (T1,
PCC)
6. Replace the I/O control board.
7. Replace the main control board.
- Signals to Check -
[A258/A259/A260]
Leak Detection:
CN227-B1 on I/O control
Board
[B017/B018]
Leak Detection:
CN221-B1 on I/O control
Feb 10, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
1,098 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
