Question about Logitech QuickCam Pro 5000 Webcam
Mic not working
Perhaps it is the VIA Host Controllers, but the mic does not work on my computer - it does on others. How can I fix it? The camera works and I can hear the other person, but I have to type! or use sign language.
    President:
  • 2,961 Answers
Check that your mic is not dissabled in the volume properties, but also check that your instant messenger is set to recognise sound and audio. The best thing to do is to try recording a short video in windows movie maker 2 to check the cam is working ok
Posted on Jun 08, 2007
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
My crystal eye web cam is completely gone from my computer.
ACER Aspire 5737Z – Acer Crystal Eye WebCam camera no found
I had the symptom where ‘no camera found’ and the device not showing in device manager (unless you expose hidden devices, but was visable via non present hardware (exposed via system variable
devmgr_show_nonpresent_devices=1)
Solution – Disable and Enable USB Controllers
1. From Device Manager
2. Right click and uninstall the Standard Enhanced the Universal Serial Bus controllers -> Standard Enhanced PCI to USB Host Controller – do this for both via right click - uninstall.
3. Right Click <YourSystemName> from the top of Device Manager, Click Scan for Hardware Changes.
4. Your Acer Crystal Webcam should now back under Imaging Devices, and working again!
5. Strange but seems to fix it, good luck!
I also pressed the top of the laptop screen to the left and right of the camera at around the same time. Not sure if something clicked back into place, either way above is a simple thing to try... Hope this helps.
Jan 22, 2010 | Acer Aspire 5610-4648 Notebook
Connection to PC no longer working
Sorry for the delay. The hotel wireless connection took a dive. If the camera works OK and it is just a message then go to Control Panel>Device Manager>Universal Serial Bus Controllers>USB Enhanced Host Controller>right click to select properties>Advanced and then check the box that says "Do not tell me about usb errors". That will stop the error messages which only mean that the camera is drawing slightly more than 500mA which is a USB 2.0 feature that you can disable to revert to USB 1.1 but not necessary if the camera works. Each of the Host Controllers has a check box like that. The USB Root Hubs below that have similar checkboxes to Reset if you ever get a message that the Root Hub needs to be reset just for your own info. This is a common annoyance and is probably more due to the USB cable quality than the camera actually drawing more power. Feel free to repost if you have any other concerns. Steve Medley
Dec 11, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
USB connection problem using Windows 98 Second Edition.
The cause of this problem can be traced to both the computer's hardware configuration and Windows 98SE (Second Edition). PhotoMAX cameras and other devices featuring USB (Universal Serial Bus) connections may not work with computers running Windows 98 Second Edition and equipped with the following computer hardware: * an AMD processor (350 MHz or higher) * VIA Technologies USB Host Controller or SiS 7001 USB Host Controller To find out what USB Host Controller is on your system: 1. Click Start > Settings and choose Control Panel. 2. Double click the System icon. 3. Choose the Device Manager tab. A window similar to the one shown below appears. 4. Expand the Universal Serial Bus controllers listing by clicking on the "+" sign next to the listing. 5. Note the type of host controller in the listing. The example above shows the SiS 7001 PCI to USB Open Host Controller.
Sep 14, 2005 | Polaroid PhotoMax PDC 1300 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax MP3 Digital Camera
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Logitech QuickCam Pro 5000 Webcam Logo
186 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
