Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
How to descale coffee maker ESAM 04.110
Followed instruction in booklet but its not doing anything?
5 Suggested Answers
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
  • 6 Answers
SOURCE: descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Posted on Jul 22, 2010
mnwarfield10
  • 452 Answers
SOURCE: Lost the instructions / booklet
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Posted on Feb 28, 2011
SOURCE: There is a flashing warning
Mostly it is just a very unreliable product. I am on my 3rd replacement after only 14 months.
Posted on May 24, 2011
"GROUND TOO FINE ADJUST MILL! Insert water spout
  1. Insert steam spout and push OK.
  2. Fill your tank and add descale solution.
  3. Go to program settings - Descale.
  4. Follow the prompts on the readout.
  5. After descale and rise are complete refill your water tank.
  6. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Sep 27, 2013 | DeLonghi Perfecta ESAM 5600 Espresso...
Dear Madam, dear Sir, I tried four times to descale my coffee machine with Philips Senseo Descaler; nevertheless, the "calc" lamp is still on. What else can I make? With cordial...
Hi. Sounds like a sencor is faulting. Try unplugging it from the power for a few minutes, then start it back up. If you dont have water coming out the your boiler maybe blocked. Id need more information to suggest anything else. Dazza REPAIRER
Sep 24, 2011 | Philips Senseo HD-7810 Coffee Maker
I have cleaned my senseo , but the red light still is on. what do i do next?
Do not turn off the machine until all 4 cycles are complete (2 descaling & 2 rinsing ). The machine will then switch itself off. This is not properly explained in the instruction booklet.
Aug 25, 2011 | Philips Senseo HD-7810 Coffee Maker
What does it need when the window reads "descale"
when the display says "Descale" it means that the machine wants to run a cleaning program to remove any limescale build up on the heating elements.
you will need to put a descaleing solution in to the main water tank and run the descale program
follow the instructions in the manual to descale
Note (useing anything but the recommended descaler may void the warranty)
Feb 18, 2011 | Keurig B70 Coffee Maker
Descaling coffee makes esam4200
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling a delonghi magnifica ESAm04
Apr 22, 2010 | DeLonghi Coffee Makers & Espresso Machines
Would like to descale I have the packet needed
No need to unscrew anything
Add the descaler sloution to water and pour it into the water tank.
Follow the instructions on the descaler packet for dosage.
Dec 21, 2009 | Gaggia Classic Espresso Machine
Descaling problem
make sure the * is on the descaling line
Jan 25, 2009 | Miele CVA615 Espresso Machine
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Sep 05, 2008 | Saeco Royal Digital Plus Coffee...
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
64 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
