Question about Sewing Machines
Where can I get replacement screw & bolt for
  • also you can try a sewing machine shop in your area to see if they have the parts.
  • Sewing Machines Master
  • 7,365 Answers
Try sewvacdoctor.com or a1sewingmachines.com
call them or email them about the parts you need
Posted on Dec 03, 2012
SOURCE: NECCHI 525FA
I have a brand new 525FA. I can try to take a pic of it tomorrow for you. I may have to call my mom to see what part you need a picture of cause I'm not familiar with sewing machine parts at all. But I'll check with her. Or maybe you can take a pick of what you need to see. Then I can look at it, and take a pic of the same thing on mine.
Posted on Jan 14, 2008
JeremySew
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
SewTechWayne
  • 186 Answers
SOURCE: faulty presser foot lifter on a singer 2110/2112.
I have seen these machines with broken presser bar clamps (something inside the head). If it is just a bind then some oil on the presser bar may work, if the clamp is broken then it is probably not worth fixing.
Posted on Jan 31, 2009
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
Hi where can I get instructions spare feet and Cotton holder for a necchi 215a
This will help you determine which presser foot shank you need for your machine. Once you know which shank fits your machine, you can purchase extra presser feet most anywhere:
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
User Guide Instructions Book Operating Manual Service manual Workshop...
As for a replacement spool pin, you can probably take your machine to a sewing machine repair shop and they can fix it for you.
May 09, 2017 | Necchi Sewing Machines
Is it possible to change the presser foot pressure on a necchi 200? I looked in the manual but can't find anything.
Newer computerized models usually have a pressure adjustment in the form of a dial on the left side of the sewing machine head.
Older machines generally did not include that information in the manuals. It is usually a screw that is accessible from the top of the machine, inside the cover--most often directly above the presser foot. Sometimes it is a plunger-type button--the further down it is depressed, the tighter the pressure.
http://makeitsew.biz/presser-foot-pressure
FWIW, if your machine does not have a pressure adjustment, you might try using other presser feet, ie roller foot, walking foot, teflon foot.
Sewing Machine Pressure Settings for Machine Quilting
Bernina 830 Record Review
Feb 19, 2017 | Necchi Sewing Machines
How do I attach the buttonhole presser to my necchi 575fa
by removing the normal foot loosen the screw holding it on the put button foot in place of it and tighten the screw back up
Feb 22, 2015 | Necchi Sewing Machines
I have a necchi 525 sewing machine and need to replace the pully leather belt
Try these web sites:
http://www.sewingpartsonline.com/necchi-525fa-sewing-machine-parts.aspx
http://drdanessmh.com/necchiparts.html
Jan 21, 2013 | Necchi Sewing Machines
Necchi 525FA. OWNERS MANUAL
try sewingpartsonline.com
Apr 08, 2012 | Necchi Sewing Machines
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
there are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Nov 24, 2010 | Janome Memory Craft 5700
I cant get my fabric to feed in my machine
feed dog & the presser foot must work togeather for the fabric to feed thru the machine
you should be able to see the feed dog when you look at the needle plate
open the door to the light that's were you'll find the needle bar adjuster that puts pressure on the presser foot,,it may be in the shape of a star or just round,,mine is set between the 2-3,,your may have numbers or letters,, adjust the it & then try to sew
Oct 21, 2010 | Necchi 3537 Mechanical Sewing Machine
I own a Necchi model 535f......I have had it cleaned and oiled in the last 4 years....I can't get my fabric to feed through my machine
The feed dog & the presser foot have to work together to feed the fabric thru the machine
The feed dog should be seen when you look at the needle plate, if not the feed dog setting should be checked--the feed dog lever may be to the right of the bobbin area
Open the light bulb door also called the Lamp Cover door or Face Plate,, there should be a knob at the top round or star shaped,, that adjusts the needle bar that puts pressure on the presser foot,, it may have numbers or letters, mine is a star shape & has numbers on it & is set between the 2-3
Adjust it a little at a time & then sew to see which setting is best for your machine
Oct 21, 2010 | Necchi Sewing Machines
Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
Nov 17, 2008 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
