We just purchased and installed the ProCom 23,000 BTu vent-free stove and hooked up to NG. Stove works great but we keep smelling gas. all connections have been checked and rechecked and there are no leaks. We thinks it might be in the burner unit got any ideas!
  • Connie Charleson Dec 05, 2012
    We read that operating the stove above an elevation of 4500 fee could cause pilot light outage we live at 5000 fett elevation. Of course they don't tell you about the elevation when you buy the heater. My husband called ProCom to ask about a solution to the (gas odor) gas/air mixture ratio due to the elevation and they said "open a window" Surely they have run into this problem before. We are guessing that the reason we are getting gas fumes is due to our thinner air. Does anyone have any ideas on how to fix this problem. All suggestions would be greatly appreciated. Thanks
  • Heating & Co... Master
  • 2,598 Answers
Differant elevation means you have a differant orffice for it to work opening a window will not help, Go back to where you got it and ask them for a orffice or get a gas fitter to change the orrfice , he should have a chart in his code book , he should have blank orfffices and can drill it out to the right size , then this should work .
Posted on Dec 08, 2012
  • Connie Charleson Dec 08, 2012
    Thanks much....drilling out the orffice to the correct size has solved theprobme. Too bad the guys at ProCom couldn't figure that one out!! Thanks again.
  • 2598 Answers
SOURCE: Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Posted on Jan 14, 2009
SOURCE: earth stove gas heater
How do you adjust a pilot light on a Gas Fireplace. The Pilot Light is at least 5 inches high?
Posted on Oct 03, 2008
  • 2598 Answers
SOURCE: Gas smell from Procom 28000 btu infared heater
check the connections with some washing up liquied and water in a bowel and try the connections with this , it should help find your leak use a paint brush to put on
Posted on Jan 13, 2009
SOURCE: I want to convert a QN300TYLA natural gas unit to
HI , I HAVE A PROPANE MODLE QL300TYLA I WOULD LIKE TO CONVERT TO NATURAL GAS , MAYBE WE CAN SWITCH PARTS.
Posted on Oct 14, 2009
heatman101
  • 43501 Answers
SOURCE: I have a ProCom FBN400TYLA vent free natural gas
Found the manual on line and copied directly from it:
WARNING
Models FBN400 are equipped for Natural
gas. Field conversion is not
permitted.
Models FBL400 are equipped for Propane
gas. Field conversion is not permitted
This should answer your question.
See if you can run the gas line or find someone to do it cheaper for you.
Posted on Nov 15, 2009
My heater did not include the adapter to hook gas line up, cannot find one listed anywhere, any suggestions
Gas supply house should have your adapter. they will probo want to connect it up themselves.
Jan 03, 2016 | Procom 10K BTU, Vent Free, 2 Plaque...
How can I lessen the flame on my vent free fire stove
sorry but no there is not either turn it off or open a window/door
Mar 25, 2015 | Heating & Cooling
Jan 13, 2009 | Procom (177653) Utility Heater
PROCOM QL300TYLA
The QL300 has a range of 20,000 to 30,000 btus. That shouldn't be too big for your 300 square foot room with high ceilings and a loft. It has a thermostat, so it will shut off when the room gets warm. 1 pound of propane contains about 21,000 btus, so you will be burning 1 to 1.5 pounds each hour that the stove is running.
Jan 17, 2008 | Procom QL300TYLA Heater
Delayed lighting
It sounds like the orifice is missing or is the wrong type (LP) on the back burner.
Dec 20, 2007 | Procom 10K BTU, Vent Free, 2 Plaque...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
