Question about Speed Queen CTSA7AWN / CTSA9AWN Front Load Stacked Washer / Dryer
Speed Queen CTSA7AWN / CTSA9AWN Front Load Stacked Washer / Dryer cuts off in mid cycle Once it cools down it will start up again. What could be the problem
    Top Expert:
  • Speed Queen Master
  • 9,472 Answers
The motor is overheating. Check to be sure there is no lint buildup on it.
Posted on Dec 03, 2012
  • 351 Answers
SOURCE: speed Queen home washer will not spin/drain
check belt size
Posted on Mar 29, 2008
  • 1214 Answers
SOURCE: SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: I have a speed queen washer. Last wash my
the seal in the transmission is bad
Posted on Feb 22, 2009
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 20 Answers
SOURCE: washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
Posted on May 23, 2009
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Washer stopped mid cycle w/ water...mid agitation.
Might just be a bad lid switch. Push down on lid or switch.
Jan 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Hi, I have a Speed Queen LTSA7AWN washer/dryer combo. It will not start hte cycle. After closing the door, the door light flashes.
This is a door lock error. The control is not seeing that the door was locked.
Try pushing the door closed where the door strike is. If this does not work you may nee to adjust the door strike.
Dec 28, 2010 | Speed Queen CTS99AWN Front Load Washer /...
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Speed Queen CTSA7AWN / CTSA9AWN Front Load Stacked Washer / Dryer Logo
107 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
