Question about Miele Microwave Ovens
Why does my convection oven fan make a clunking sound?
The longer the convection oven is on, the more fan clunking noise is audible. We have cleaned the oven but clunking sound seems to be getting worse
  • 3 Answers
SOURCE: does microwave ovens make noise while it is in process of heating?
It seems like it is the first time you either own or using a microwave oven. Yes, there are more than one fan/motors inside a microwave, depending upon the model/type.
Posted on Nov 04, 2008
SOURCE: clicking noise of fan on convection
The motor on the fan has to be replaced.The fan is hitting the screen .Hopfully that will fix it .Thank you .
Posted on Nov 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Rattling Fan Noise
If I had to bet, I would say the fan blade assembly is loose on the fan motor shaft.
If so, a spot of super glue where they meet will usually take care of that.
If that's not it, it should be investigated.
It is vital that the cooling fan runs properly, or the magnetron will be destroyed.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After you look into this, if you still need help, please write back with more details.
Posted on Jan 03, 2009
ghost4548
  • 776 Answers
SOURCE: GE COMBINATION MICROWAVE CONVECTION OVEN JVM1790BK CONVECTION OVEN DOES NOT GET HOT
change the tube/heating element
Posted on May 26, 2009
bestdarngood
  • 3037 Answers
SOURCE: convection function not heating from underneath
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
I have a panasonic convection/microwave. Last night, after I cleaned it, using oven cleaner on a sponge, it made a loud humming noise after running on microwave for about 10 sec. It does not make the noise...
Since the unit makes the noise on Microwave but not convection it is a problem it he Microwave Circuit. Probably in either the rectifier of bad mag, one of them shorted. Just looked at the date you posted this, Im sure you have fixed or replaced this by now
May 31, 2017 | Panasonic NN-C980 Convection/Microwave...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Clicking noise of fan on convection
Nov 05, 2008 | Sharp R-1850A Convection/Microwave Oven
Does microwave ovens make noise while it is in process of heating?
Nov 04, 2008 | Microwave Ovens
No sound from unit when making pad selections
From page 24 of the owner's manual:
Audible Signal Elimination
If you wish to have the oven operate with no audible
signals, touch HELP GUIDE, the number 2 and
STOP/CLEAR.
To cancel and restore the audible signal, touch HELP
GUIDE, the number 2 and START.
If you don't have your owner's manual, I've uploaded it to our site for your convenience:
http://www.microwavedisplay.com/dcm24_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Dacor DCM24 Convection/Microwave Oven
Integra fan convection - rsa regency
you might be able to just clean the ignitor to get it working again. Take it out and give it a good cleaning. If that doesn't work then it could be your spark module. If it is your spark module it will have to be replaced. I have replaced spark modules and ignitors of ovens or ranges that you can no longer get parts for with whirlpool modules and ignitors. There are basically two types, just make sure you get the same type. One type , typically used by GE uses a continous ignitor that glows when it works, and Whirlpool (on most models) uses the spark module and ignitor that makes the clicking sound like your oven did for ignition.
Jul 24, 2006 | Bosch HLK4525GB Convection/Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
k24674
Armin Buehlmann
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
