Question about Toshiba 32AV502U 31.5 in. LCD HDTV
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE CAN SEE PICTURE BUT IS VERY SNOWY I TRIED ALL INPUTS WITH CABLE DVD AND A GAME SYSTEM BUT NOTHING CHANGES AND THE WIERD PART IS WHEN I HIT THE MENU BUTTON THAT COMES UP CLEAR AND PERFECT I DONT GET IT NO SNOW ON THE MENU BAR AT ALL
  • spencercusto Dec 04, 2012
    i checked all the settings and everything seams ok but i still have the snow on the screen but i can still see the menu screen and set up screen clear its just the viedo input thats snowy and all of the inports
    New Friend:
  • 8 Answers
Check the picture settings in the menu... someone may have been fiddling with them
Posted on Dec 03, 2012
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
SOURCE: I have a 32
hi i have a regza 32 and i have sound tele text etc but no picture!! Help please
Posted on Sep 08, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
SOURCE: Toshiba 40RV525U goes into green screen mode when
Try updating the firmware to version 1.05 from this website http://support.toshiba.ca/support/ceg/downloads/all/view.asp?docid=D000020
Testimonial: "daubuchon..thanks for the info! That might have done the trick. The problem is much less prevalent now. Excellent!!"
SOURCE: Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Posted on Jul 12, 2010
MY SAMSUNG LCD TV MODEL LNS4695DX HAS A SNOWY PICTURE CAN SEE PICTURE BUT IS VERY SNOWY I TRIED ALL INPUTS WITH CABLE DVD AND A GAME SYSTEM BUT NOTHING CHANGES AND THE WIERD PART IS WHEN I HIT THE MENU...
The OSD comes from a different area---if on all inputs it is on a board that processes all signal in the set--tuner,AV etc
You might want to Google the model number with "parts" to come up with a list of the boards and prices if possible for them.
Dec 04, 2012 | Toshiba Televison & Video
Snowy picture
Can you say it does it on all inputs including DVD etc?
Snow in the picture to me does not indicate a T-conn board.
Jun 15, 2012 | Samsung LN-S4051D 40 in. LCD Television
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Have snowy picture
Try hooking up a DVD player to the set. If you get a picture and have sound then you might have a issue with the source you are trying to watch. If no source inputs work the you might have a bad main bd. Have a trained Samsung tech troubleshoot the tv.
Jul 08, 2009 | Samsung LNR2668W 26 in. HD-Ready LCD...
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 32AV502U 31.5 in. LCD HDTV Logo
281 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
