Question about Maax RainForest - Three-Piece Corner Shower Unit with MAAX IES and Door Fra
Temperture control no hot water
What the temperture suppoe to be in the heater on a 2006 saturn ion 2 2.2L?
Check the water hoses that go to the heater core under the hood. Depending on the thermostat, your water temperature should be around 190-200 degrees.
Jan 19, 2017 | Saturn Cars & Trucks
WATER COMING OUT OF MUFFER
This happens because of the difference of temperture between the hot engine exhaust and cooler outside tempertures. Its why you see exhaust during colder outside tempertures.
Mar 20, 2013 | 1997 GMC Jimmy
Drying light flashes after pre wash cycle
check water temperture might be to low might turn the hot water temperture up, water temperture for best wash is 120 degree
Dec 21, 2017 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Temperature control
Well I thought a 92 model used a vac control valve on one of the heater hoses, but I don't see one listed.
If there is no control valve, the temp is controlled by blend doors under the dash.
Something is not closing the air from the heater core, or blocking the hot water from flowing thru the core.
Dec 11, 2012 | 1992 Chevrolet S-10
Temperture gauge on hot but heater does not work
check termastat ? sounds like its not opening ,feel hoses at heater at bulk head for hot or cold ? plus heater controls and metrix .have system checked by a garage ? caution very hot water ?
Sep 07, 2011 | 2002 Buick Century
Hot water temperture will not go over 33 degrees
Check your water heater thermostat on you water heater tank, look for a small removable panel, remove the insulation and then you should expose the thermostat of the water heater
Readjust the thermostat to the desired temperture just be sure not to set to high to cause problems with small children.
Apr 11, 2011 | Home
Water temperture control seems to be backwards cold temp. is hot water and hot water setting is cold. is the switch broken?
its possible, but first thing you should do is double check the connection of the hose to water inlet valve. you may just simply have to switch the hose connection around.
Feb 09, 2011 | Kenmore Washing Machines
How to adjust temp control for sigle lever shower control
Temp control is only accomplished by moving handle to desired position. If your asking is the hardware that in behind the single lever going to allow for adjustments, then the answer is NO. I installed the same into one of my bathrooms several years ago and I know what I am talking about. The single handle on that type on mine starts off then cold to hot. Problem is I wait for hot water to max so I can adjust it down to a comfortable temperture to prevent being burned. I refuse to buy one for other tubs. The 2 handles make temperture much easier with less wasted water used until its hot. Remember if you decide to replace with a two lever model then you will have to replumb the pipes for a two handle hardware unit (thats the stuff behind wall that your single handle goes into to which is currently plumbed for a single handle hardware unit.)
Oct 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
2006 toyota tacoma heat wont shut off
put a pipe clamp on one of the feed pipes for the heater that will shut if off
Apr 05, 2009 | 2006 Toyota Tacoma
Maax RainForest - Three-Piece Corner Shower Unit with MAAX IES and Door Fra Logo
44 people viewed this question
Top Maax Plumbing Experts
Steve
obsteiner
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
