Question about Ovens
I need to replace the ERC on a GE double oven model # JKP45WP3WG
  • Nancy Mora Dec 10, 2012
    The part I need is no longer available. The part that was recommended is not what I need. I am having that part refurbished.
    Top Expert:
  • 9,472 Answers
Here is the part you requested.
Posted on Dec 03, 2012
aborcass
  • 2651 Answers
SOURCE: CODE F1 AND OVEN DOES NOT WARM UP ABOVE 250
looks as if th ef1 only pertains to the erc(electric range control), the switch membrane qould be an f7 (shorted key pad, the oven sensor os diff code all together
Posted on Feb 27, 2008
captaynkyrk
  • 170 Answers
SOURCE: replace oven ignitor for ge profile oven
If you go to this link: http://www.partselect.com. You can put in your make and model number in and get a diagram of your oven and see how it goes together. You can also order parts online, or at your local appliance parts store. Good luck!
Posted on Jul 20, 2008
  • 16 Answers
SOURCE: GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
shorted touch pad(memberant)becareful remove ribbon cable clean and reseat you can test the touch pad alot of the touch pad failed because the heat(poor design cheap make)
Posted on Mar 12, 2009
SOURCE: Replacing ERC on GE oven
I ran into the same problem replacing my new part. The instructions indicated that the GROUND wasn't used. The Nuetral was located in near the same position. The L1B went to the little black box near the vacant L1B location on the board
Posted on Dec 01, 2009
award462
  • 395 Answers
SOURCE: No User Manual for double GE Profile Ovens
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Gene
Aug 04, 2011 | GE Ovens
GE model # jkp27 error code F1 what should I do?
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Thank you for using FixYa.
Apr 27, 2011 | GE JKP27 Electric Double Oven
!0 year old GE Profile Double Oven. Control Panel repaired but oven is again not working with a "F7" mal function indicator on panel. Model # JT 950 S0A3SS
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Ovens
Have a GE Monogram Oven Single Wall Unit. Began Flashing F1 last night. Model GL2788960. Its hard wired so I turned off breaker let it cool down and turned back on. Still Beeping.
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 18, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double wall oven, model number jkp26gotibb has an f1 error code. Part is no longer available. Is there any other way to fix this problem with out replacing the whole oven.
(Clock).
Dec 16, 2010 | GE Built-In 24" Double Electric Wall Oven
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
GE DOUBLE OVEN MODEL #jkp28b0f7bb FLASHES CODE #F7 EC AND BEEPS . WHAT IS MOST LIKELY PROBLEM
F7 indicates a stuck button or the erc electronic range control has failed. First check each button one at a time and feel for a click and full retraction any abnormalties replace the key pad. If that checks out good the erc will need replacing. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | GE Ovens
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
GE JTP27 oven, ERC display completely lit, keypad
Yes, this is a problem with the ERC. You can buy a new one, or we can rebuild it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | GE JTP27 Electric Double Oven
F8 on Ge JTP27 Whats wrong?
The reason to get F8 is that the component failure that occured within the Electronic Range Control (ERC) effecting temperature processing circuits. Th perfect fix for this problem is to replace Electronic Range Control (ERC).
Sep 04, 2009 | GE JTP27 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
