About 30 seconds after i press start and active button ignites machine just goes to end button without doing anthing
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the complete model number of your unit?
Could you please describe the problem you are having a little better?
Posted on Dec 03, 2012
barkencoa
  • 3463 Answers
SOURCE: only works on 30 degrees
If it is a hot and cold fill m/c.then make sure that you have water present at both valves.
Posted on Dec 03, 2008
SOURCE: simpson ezi loader washing machine clicks 3 times
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Posted on May 03, 2010
Trickyrobb
  • 12 Answers
SOURCE: Hi When you load our machine
Press cancel?
Posted on Oct 04, 2010
  • 14 Answers
SOURCE: when i press start button machine takes in
if it need moore than 8 min.to fill up with water,you must clean up that filter from inlet hose.
Posted on May 23, 2011
  • 7 Answers
SOURCE: I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Posted on Jul 26, 2011
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
2000 328ci got a new key and it needs to be activated to the car ,whats the steps fpr that sync?
Enter vehicle,make sure all doors,windows are shut
Use first key,switch ignition on and off
Remove key PRESS AND HOLD UNLOCK BUTTON
PRESS LOCK BUTTON 3 TIMES,RELEASE UNLOCK BUTTON
Central locking will activate
SECOND KEY, DO NOT INSERT IN IGNITION
Within 30 seconds press and hold unlock press lock 3 times release unlock button
Oct 03, 2010 | 2004 BMW 3 Series
Car wont start after getting a new key and replacing batteries -
hi well this is a bit long so if you can bare with me i will try explain how to , clear system to decode, and recode as this is what it sounds like that the coding has gone from the ignition key....ok here goe's
to sync key with car depress lock or unlock button manually lock the drivers door within 30 seconds of the above system should now work....if not do next bit
switch ignition on ( using non chip key ) manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that's the de-programming done...
to de-program the system if above fails..........
switch ignition on ( use key without remote ) manually lock drivers door using key to be synced with car complete the following within 30 seconds of doing above within 5 seconds press the unlock button on key indicators should flash once wait 5 seconds press unlock button once to confirm programming vehicle should unlock this also will confirm deactivation of programming mode switch ignition off remove key..that should be it, then try new programed key in ignition.
to re-program system and sync with key switch ignition on manually lock drivers door using key ( another one, hopefully you will have more than one) press unlock button 5 times, in one second intervals indicators flash 5x for every time signal is received switch ignition off and remove key
that should be it, if no joy then will have to main dealer i am afraid...hope this helps
Jun 07, 2010 | 2001 Audi TT
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to find a way to disarm alarm for Ford Contour Sport, 1996. Also it will not start
Many Ford trucks, vans and suvs use PATs (passive anti-theft) keys. These keys prevent someone from copying your key to a blank and using the blank. There is a small chip in the key which the vehicle must recognize before it will start.
PATS is Ford Motor Company's passive anti theft system. In 1996 it started showing up on select models of Ford and Lincoln Mercury vehicles. The keys for these vehicles have a tiny radio frequency transponder imbedded in the plastic Head.
pats_key.gifWhen you attempt to start the vehicle, the onboard computer sends out a RF signal that is picked up by the transponder in the key. The transponder then returns a unique RF signal to the vehicle's computer, giving it the ok for the vehicle to start and continue to run. This all happens in less than a second, and is completely transparent to the vehicle operator. It is a very effective system that does its job without the vehicle owner having to think about it, or modify his / her usual routine.
The PATs key is used on the following Ford family trucks and SUVS:
1998-up F-150
1998-up Expedition
2000-up Excursion
1998-up Explorer
1998-up Ranger
1998-up Lincoln Navigator
1998-up Mercury Mountaineer
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system.
Hope this help you (remember comment and rates this).
Apr 04, 2010 | 1996 Ford Contour
What's the code so the doors don't lock automaticly....what a pain this feature is.
page 10 of the book for the durango
1. Close all of the doors.
2. Place the key in the ignition and cycle the key from the OFF position to the ON position for a total of four times ending in the ON position, do not start the engine.
3. Press the drivers side power door lock switch to lock the doors within 30 seconds.
4. You will hear a single chime when the programming is completed.
5. To activate the feature again, repeat the above steps.
...And from pages 12-13:
To unlock the doors and liftgate: Press and release the UNLOCK button on the key fob once to unlock the driver's door, or twice to unlock all doors and liftgate. The illuminated entry system will also come on. The system may be programmed to unlock all the doors, on the first press, using the following procedure:
1. Close all the doors.
2. Place the key in the ignition and turn the key between the OFF and ON position consecutively for a total of four times ending in the ON position (do not start the engine).
3. Press the driver's side power door lock switch to unlock the doors and within 30 seconds to lock the doors.
4. You will hear a single chime when programming is completed.
Aug 21, 2009 | 1999 Dodge Durango
1999 Chrysler Town and Country
Have you you tried just re-programming all of your remotes? I just added a "new" (from Ebay) remote and when re-programming, had to do them all. Here's how... 1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System. 2. Insert ignition key into the ignition switch. 3. Turn the ignition switch to RUN position without starting engine. 4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds) 5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s) 6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful. 7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total) 8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s) 9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Aug 03, 2009 | 1999 Chrysler Town & Country
Child lock and spin/end lights on and stuck need to reset
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
