I have a roper top load washing machine. we recently replaced the couplet. I just ran a small load of sheets and after the wash cycle it began filling my house with a terrible smell. It smells very hot.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Sound the the coupler is installed wrong or the pump is locked up.
Posted on Dec 03, 2012
SOURCE: Egg Smell
We fell prey to the same desire to have the state of the art, economical and supposedly gentler on your clothing front loading washing machine. Bosch WFK 2401 and I have found a solution but it is not pretty for those of you who have a washer not hidden in a laundry room.
I keep the kick plate off at the base of the front of the washer. Using a low profile pan, an 8 x 8 cake pan is about right and immediately after every wash plase the small drain hose over the pan and open it. The pan fills about half way with water that is left in the bottom of the drain system. Doing this prevents the next load from being exposed to the rotten egg water.
It must be done at the end of every load. I too keep the front door open when not in use and pull the detergent/softener draw open as well.
Good luck. Can hardly wait to justify that I have lived with this long enough to purchase a new top loader!
Posted on Aug 09, 2009
  • 100 Answers
SOURCE: diesel smell in washing machine
Try using a cup the the same soap you would put in your dishwasher and run is with the hottest wash setting possible
Posted on Oct 30, 2007
  • 11 Answers
SOURCE: smelly washing machine
Run a wash cycle with only some bleach in it. That works for us everytime ours gets a bit stinky... Good luck!
Posted on May 19, 2008
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
  • 714 Answers
SOURCE: Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
Posted on Jan 17, 2010
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Washing machine stops after final rinse cycle
Your lid switch is bad. It must be replaced.
Jun 26, 2009 | Whirlpool Washing Machines
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper Washer
Most likely to be something in the water pump but could be anything in the mechanical assembly. PLease rate my help
Oct 02, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
