Question about Pioneer Stereo Compact Disc Tape Player Changer Am Fm Bookshelf Receiver Xr-z82
CD player will not start on pioneer XR - P500
When player takes tray with disc in , it will not start to play
SOURCE: Pioneer 301CD Player PD F1009 disc tray jammed
I had this same problem today on my pd-f1007
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Posted on Jan 06, 2008
SOURCE: pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
starlet4life
  • 89 Answers
SOURCE: Pioneer automotive stereo cd player error 11
Error 11 is probably the laser...;)
Posted on Sep 26, 2008
  • 51 Answers
SOURCE: Pioneer DV535 Player
That sounds like a problem that needs professional service. The door may have jumped a gear, or there could be a circuit malfunction. At any rate, it's probably cheaper to buy a new DVD player. CD and DVD technology are quite precarious still, and I wouldn't expect more than a couple years service from most DVD players.
Posted on Jan 02, 2009
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
Pioneer cd reads disc but wont play?
Look for a different one,It will cost you less then having it repaired,
Nov 04, 2012 | Pioneer Audio Players & Recorders
I "stupidly" put two disc
I think your best option is to take the top off and see if you can straighten the pin.
If not then you may need to replace one or both of the trays.
Tray 1 Part No. PNW2709 around $30.00
Tray 2 Part No. PNW1840 around $12.50
Apr 21, 2011 | Pioneer PD-V10G 2-Disc CD Player
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Pioneer DV 310 K region free
Step 1) Download the pioneer firmware here http://www.pioneerfaq.info/index.php?question=Firmwares
The site says the firmware only works on region 2 players. For this model it worked for my region 4 player in Australia
Step 2) Burn this file to a CD-ROM with name PIONEER as per these instructions - http://www.pioneerfaq.info/english/burn_guide.php
Step 3) Load the CD and your DVD player with ask you to flash the firmware. It says press play to start but instead HOLD DOWN ENTER during the entire process. DO NOT switch off your DVD during this time. When the tray opens take the CD ROM out but keep the DVD on. The flashing can take up two to three minutes. During this time HOLD DOWN ENTER ON THE REMOTE. The entire time!
Step 4) The DVD player will reboot. The tray should be empty. It will then load the tray back into the player. If the signal is disorted switch on and off.
Your done! Should work.
The most complex way of region freeing a DVD I have ever endured! :)
Jul 19, 2009 | Pioneer DV-310 DVD Player
Pioneer cdx 12 disc changer
According to manual code simply means electrical or mechanical fault - not extremely helpful.
Try to disconnect and reconnect power and it perhaps will reset the problem.
Feb 03, 2008 | Pioneer CDX-FM1289 12-Disc CD Changer
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
Will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer Stereo Compact Disc Tape Player Changer Am Fm Bookshelf Receiver Xr-z82 Logo
54 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
