Question about Creative Labs Inspire T7900 Computer Speakers
Creative inspire T7900 remote control not working...need 9-pin DIN connector configuration...
Volume control pin configuration, schematic, circuit diagram needed....for making new controller..
2 Suggested Answers
SOURCE: remote volume control needed for Creative Inspire 4.1 4400
Dear sir
I brought sound system, but unfortunately I miss place volume control, I would like to ask suggestion without volume control could i operate sound system....... could i get seprate part to buy from delers or mfg.
please advice.
Thanks
maheshrn2002@yahoo.com
Posted on May 02, 2010
Hi frends i need to remove volume control from my t7900 and direct it from main board plz solve it
uninstall the sound driver from device manager in my computer's properties...
if u have any other problem about your computer so can contactwww.itechsupportgroup.com
May 04, 2012 | Creative Labs Inspire T7900 Computer...
Please did you have creative labs inspire T7900 power cable in store
Here is a list of all the different power adapters and specifications from creative. To buy the power cable try newegg.com, or the creative store, or call their tech support.
Mar 04, 2011 | Creative Labs Inspire T7900 Computer...
An i get the diagram for the ON OFF switch and volume control? mine is damaged i like to fix it
-"Can i get the diagram for the ON OFF switch and volume control?". I built mine based on a schematic generated by tracing the printed circuit board of a working unit. Some component values are non-standard but I just used the nearest standard values. The ON/OFF switch was also replaced by a toggle switch because the original is an integral part of the volume control. The 9-pin mini DIN connector presented the greatest hurdle in my part of the world but got lucky cannibalizing a discarded Strobe Pro scanner. The completed unit worked as charm. The schematic can be found here: http://i1192.photobucket.com/albums/aa327/aguinart/Creative5200.jpg.
Feb 22, 2011 | Creative Labs Inspire 5200 Computer...
T7900 side speakers not working
Once you have installed the drivers for your sound card you will need to do the following.
Click start menu > Control Panel > Sound.
In there select the speaker tab by left clicking on it once.
At the bottom left hand of the window there will be a button that says configure.
In there you will have a series of options in which you can change the speaker configuration for your speaker setup.
The above instructions are assuming you are using windows 7 as you haven't told us what operating system you use.
Feb 19, 2011 | Creative Labs Inspire T7900 Computer...
Creative inspire T7900 7.1 stopped workin
Power light on at the volume knob?
plugged in all the way at the soundcard?
try other speakers even a stereo set to ensure soundcard not a fault?
Apr 19, 2009 | Creative Labs Inspire T7900 Computer...
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Dec 19, 2008 | Bose Companion III Computer Speakers
Creative T7900 Speakers
ODDS are slim without a connecting unit best bet to accomplish this is to get the dds-100 by creative good luck though as this item is discontinued and expensive even still to date. you will need osmething to decode the signal from the tv. a receiver with any surround capabilities will also work
Nov 10, 2008 | Creative Labs Inspire T7900 Computer...
Got t7900`
I have had that problem with a T7700/T7900 speaker system.
Disconnect the remote control from the subwoofer. Then what you need to do is unscrew the remote volume/bass control unit (4 little screws). Swab the contacts on the volume dial with a cotton bud (q tip) denaturated alcohol or even perfume will work. Make sure you do it several times until all the slight dirt that is causing the volume fluctuation/spikes to happen. Also remove any remnants of cotton that might get stuck.Now you'll have it working as new as long do not cause any other damage to the unit.
Cheers,
Daniel
Jul 02, 2008 | Creative Labs Inspire T7900 Computer...
Creative Labs Inspire T7900 Computer Speakers Logo
286 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
