Question about Nikon 75-240 F4.5-5.6D AF ZOOM-NIKKOR Lens
Remove lens-hood remove HB21 Lens hood
2 Suggested Answers
  • 5 Answers
SOURCE: lens hood can't be removed from 18-105mmAF-S DX VR lens-stuck in
i don't want to preach.. but what's that hood diong there? but whatever the reason is i'll be helping you. simplest way is not to stop shooting therefore you won't face the same problem. glad to be of help.
Posted on May 07, 2009
Lens hood
Apparently the lens hood is too narrow for the current focal length. Either zoom in to narrow the field of view or remove the lens hood.
May 02, 2012 | Nikon Coolpix L120 Digital Camera 14.1mp...
Petal lens hood is showing around the edges of shot
May 02, 2012 | Cameras
How do you replace the headlight on a 2002 Daewoo Lanos
Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
  • Find the hood release handle and activate it, the hood should pop open.
  • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
  • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
  • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
  • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
  • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
  • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
  • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
  • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
  • Re-install the headlight lens housing and reinstall electrical connector.
  • Re-install plastic covers.
After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
Glad to be of help!!!
Jan 21, 2011 | 2002 Daewoo Lanos
I have a 2nd hand nikon d80 - when i use the flash, i get a black shadow on the screen.
You didn't specify the lens, but I'll bet you're getting the shadow of the lens hood. Try removing the lens hood.
Dec 29, 2009 | Nikon D80 Digital Camera
We just bought d90 nikon camera and we found a small half-round shadow at the bottom of the pictures taken when we dont use the zoom lens, how do we correct this?
Are these pictures taken using the built-in flash and with the hood on the lens? If so, you're seeing the shadow of the lens hood.
Remove the lens hood when using the built-in flash.
Sep 17, 2009 | Nikon D90 Digital Camera with 18-105mm...
Lens hood can't be removed from 18-105mmAF-S DX VR lens-stuck in
Mar 15, 2009 | Nikon D60 Digital Camera
Canon efs17-85mm image stabilizer lens
This is called "vignetting". To me it sounds like your lens hood isn't mounted correctly. If you don't turn it on all the way, exactly this will happen, because the longer "leaves" on the hood shadows the edges of the frame.
So, try to turnt the hood all the way on. You might have to use a little bit of force, as the hoods can be hard to turn sometimes.
Hope this helps!
/Chris
Jul 09, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Lens Hood question
You couldn't be more on-course if you had a GPS and compass. Yes, the little door on the underside of Pentax plastic petal-style lens hoods is to allow access to adjusting polarizing filters without removing the entire hood.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Nikon 75-240 F4.5-5.6D AF ZOOM-NIKKOR Lens Logo
15 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
