Question about Cameras
I have a samsung m100 camera,not it's lense dost not come out when the push power switch is on position.In this position no key is working and display only wallpaper for a moment.
To off the camera battery has to be disconnected.And when i switch on my camera then it does two beep sound.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Posted on Dec 03, 2012
SOURCE: Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Posted on Mar 31, 2008
SOURCE: samsung L730 won't come on...
how about give us our money back!
Posted on Jan 09, 2009
SOURCE: Beeps repeatedly, lense won't retract...won't take pictures?
I had all the same problems with the camera that first started with a "memory card error" (the memory card was not the problem). I also only could get a "background" screen on the LCD. I was totally frustrated to the point that I figured I'd have to buy another camera. So, I figure it wouldn't hurt to manhandle the camera. I lightly tried to pushed the lens back in while pressing the power on-off button... The camera lens pushed and jerked (I didn't really fight the push). Thinking I did nothing... I then tried turning it on again....like magic, the camera turned on normally with screen showing ready to take the next picture. And no more "memory card error" either. I don't really know how this worked, or whether it'll work for anyone else, but it did for me.
Posted on Aug 03, 2009
  • 11967 Answers
SOURCE: My camera wont turn on (its not the batteries).
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 25, 2010
  • 1382 Answers
SOURCE: Kodak m1033 lenses stuck 'open'.
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 14, 2010
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home · Small Business ...
Jan 03, 2016 | Home Security
Thermoset is set to off but keeps beeping constantly...anyway to disconnect to stop the beeping? Batteries were recently replaced..no battery indicator light is showing. I want to take a hammer!!
Can you provide me the model number of the unit? The model number starts with 1FXX-XXX. So that i can verify if that thermostat is capable of creating a beeping sound.
Jul 12, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I want to disconnect the beep sound when I press record
From the manual:
"When [BEEP SOUND] on the [INITIAL] Sub-Menu on
the [TAPE RECORDING MENU] is set to [ON],
confirmation/alarm beeps are issued as follows.
1 Beep
• When you start recording
• When you switch the [OFF/ON] Switch from [OFF] to
[ON]
2 Beeps
• When you pause recording
2 Beeps 4 times
• If you perform a wrong operation before or during
recording."
Aug 16, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Digital Camera Lens Problem
Read someone had the same/similar problem. Lens sensor at fault or broken. Camera not really worth the expense of a repair.
May 10, 2008 | Pentax Optio 430RS Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
S500
This sounds like a battery problem.  Make sure that it is fully charged or you replace the batteries and clean all battery contacts in addition to using some canned air to blow out the camera.  Let me know if this works, if not I will research it further.
Dec 31, 2007 | Samsung Digimax S500 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
