Question about Canon Office Equipment & Supplies
Canon l2000 fax. System error E100 - Canon Office Equipment & Supplies
5 Suggested Answers
  • 9 Answers
SOURCE: I have a fax machine Cannon Super g3 laser class
toner cartridge problem! check the actuator from the drum cartridge! maybe broken.....
Posted on Jun 09, 2010
canontech
  • 1219 Answers
SOURCE: error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Posted on Jun 14, 2010
canontech
  • 1219 Answers
SOURCE: system error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Cause: (1) Shorted/broken wired main thermistor
(2) Shorted/broken wired sub thermistor
(3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
(room temperature of 20°C), replace the fixing film unit.
(2) Turn the power off and remove the fixing unit from the machine.
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
(3) With the fixing film unit removed, if there is no continuity
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Posted on Jun 30, 2010
Testimonial: "thanks buddy its very helphull for me thanks again"
Jimsta01
  • 405 Answers
SOURCE: canon
This means poor line conditions, check the connection, make sure its plugged directly to Wall jack and not into any splitters or extentions. You can also try another Jack or wire.
If you are able to fax out to other parties except for one, there may be an issue on the other end.
Posted on Jul 03, 2010
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Canon fax L2000 system error 004
Jun 27, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
System error 004
TRY THIS:
Jun 24, 2010 | Canon Office Equipment & Supplies
Error code e100 on canon laser fax L100
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
E100 error
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Dec 18, 2008 | Canon LaserCLASS Fax 710 Printer
System Error E100 steadily on
You have laser related error, it could be bad laser controller pcb, or laser unit.
Nov 04, 2008 | Canon L120 Fax Laser Printer
Canon laser fax 710 error message 100
e100 is a laser failure.... replace the laser assy
Oct 30, 2008 | Canon LaserCLASS Fax 710 Printer
Cannon l120 laser fax shows sytem error E100 and alows nothing to be done to it.It has worked for a few months now. Help!!!!!!!!
According to the knowledgebase on Canon USAs web site, System Error Exxx may be corrected by removing all power (unplug) for ten seconds, then plugging it back in.
Jun 30, 2008 | Canon Office Equipment & Supplies
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
375 people viewed this question
old marine
old marine
