Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Turns off after switching on - Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Set is not making it from standby to full on---either in its power supply or something anywhere in the set is pulling voltages down(short).
Only simple thing to "look" at is on power supply board look for bad caps:
turns off after switching on - 12_3_2012_6_12_02_pm.jpg12_3_2012_6_12_20_pm.jpg
Posted on Dec 03, 2012
Testimonial: "thank you for this"
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
Passenger side turn signal flashes faster but dont work even at day runing light, comes on when head lights are on, replace bulb and socket because was melted but stilldoes the same
Turn Signal Lamps
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
The Rear Turn Lamp
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
Oct 11, 2015 | 2001 Pontiac Montana
No turning signals
Turn Signal Lamps
The turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL, CORN LPS Fuse. Battery voltage is then applied through the TURN SIGNAL, CORN LPS fuse circuit to the hazard warning switch. The hazard switch supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the body control module (BCM) . The front turn lamps are grounded at G101. The rear turn lamps are grounded at G301 and G302.
Turn Signal Lamps and/or Indicators Inoperative
  1. Turn the ignition switch to the ON position.
  2. Place the turn signal switch in the LH and RH on position.
Do the turn signals operate properly?
Go to Testing for Intermittent Conditions and Poor Connections yes
Go to Step 3 no
Are all of the turn signal lamps and indicators inoperative?
Go to Step 5 yes
Go to Step 4 no
Are only the turn signal indicators inoperative?
Go to Step 16 yes
Go to Step 9 no
5
Check the TURN SIGNALS CORN LPS fuse for an open.
Is the TURN SIGNALS CORN LPS fuse open?
Go to Step 25 yes
Go to Step 6 no
6
  1. Disconnect the hazard switch.
  2. Turn the ignition to the ON position, with the engine OFF.
  3. Connect a test lamp between the ignition positive 1 voltage circuit of the hazard switch and a good ground.
Does the test lamp illuminate?
Go to Step 7 yes
Go to Step 27 no
7
Connect a test lamp between the ignition 1 positive supply voltage circuit of the hazard switch and the ground circuit of the hazard switch .
Go to Step 8 yes
Go to Step 23 no
8
  1. Install a fused jumper between the ignition 1 positive voltage circuit of the hazard switch and the turn signal flasher signal circuit of the hazard switch.
  2. Place the turn signal switch in the RH on position and the LH on position.
Do the turn signal lamps illuminate?
Go to Step 17 yes
Go to Step 15 no
9
Is a front turn signal inoperative?
Go to Step 10 yes
Go to Step 13 no
10
  2. Disconnect the inoperative front turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative front turn signal lamp and a good ground.
  4. Place the turn signal switch in the appropriate ON position.
Does the test lamp flash ON and OFF?
Go to Step 14 yes
Go to Step 11 no
11
  1. Disconnect the body control module (BCM) connector.
  2. Connect a test lamp between ground and the front turn signal switch signal circuit of the BCM.
  3. Place the turn signal switch in the appropriate ON position.
Go to Step 12
Go to Step 22
12
Test for an open or for a high resistance in the supply voltage circuit of the inoperative front turn signal lamp. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 34
Go to Step 21
13
  2. Disconnect the inoperative rear turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal lamp and a good ground.
Go to Step 14
Go to Step 28
14
Connect a test lamp between the ground circuit of the inoperative turn signal lamp and supply voltage circuit of the inoperative turn signal lamp.
Go to Step 20
Go to Step 26
15
Test for an open or high resistance in the turn signal flasher signal circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 34
Go to Step 18
16
  1. Turn OFF the ignition.
  2. Disconnect the instrument panel cluster (IPC).
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal indicator and the instrument panel cluster (IPC) ground circuit.
Go to Step 19
Go to Step 24
17
Inspect for poor connections at the harness connector of the hazard switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 30
18
Inspect for poor connections at the turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 29
19
Inspect for poor connections at the instrument panel cluster (IPC). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 31
20
Inspect for poor connections at the inoperative turn signal lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 32
Sep 05, 2015 | 2001 Oldsmobile Intrigue
My right front turn signal not working the bulbs are good and so is the fuse but I don't have fire going to them it's a 2010 chevy 2500hd
You don't have fire , never heard it called that before ! Battery voltage , power but never fire ! An open CTSY fuse located in the I/P fuse block will affect the operation of the right front turn signal only
Turn Signal/Hazard Lamps When the turn signal switch is placed in either the left or right position, a ground signal is completed from the turn signal switch to the BCM. When the hazard flasher switch is activated, a ground signal is completed from the turn signal/hazard switch to the BCM. The BCM then sends an ON-OFF voltage signal through the fuses to the appropriate turn signal and side repeater (export only) lamps or to all of the turn signal fuses for hazard operation. The driver door switch and passenger door switch also receive voltage from the BCM turn signal supply voltage circuits for the mirror turn signals. The door switches have no function or control of the mirror turn signals other than a pass through connection for the circuits. The audio chime is also activated when the turn signals are ON. The instrument panel cluster (IPC) receives the signals to activate the turn signal indicators over the GMLAN serial data system. When the hazard switch is pressed, all turn signal lamps will flash including both IPC turn indicators.
Ground is applied at all times at G201 to the turn signal/multifunction switch. The turn signal lamps may only be activated with the ignition switch in the ON or START position. When the turn signal/multifunction switch is placed in either the TURN RIGHT or TURN LEFT position, ground is applied to the body control module (BCM) through either the right turn or left turn signal switch signal circuit. The BCM then applies a pulsating voltage to the front and rear turn signal lamps through their respective control circuits.
Jun 25, 2015 | Cars & Trucks
My harley wont start
Key fob MUST be present near bike!
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
TO ENTER NEW PIN:
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Aug 10, 2014 | 2011 Harley Davidson FLSTC Heritage...
Flashers won turn off on my flstf 1991
Have you tried to deactivate them?
To Activate
Turn the ignition switch to IGNITION with security system disarmed (fob present, if equipped).
Press the left and right turn signal switches at the same time.
Turn the ignition switch OFF and lock the switch. The four-way flashers will operate for two hours. The security system (if equipped) will automatically arm.
To Deactivate
Have the fob present to disarm the security system (if equipped).
Unlock the ignition switch and turn the switch to IGNITION.
May 20, 2014 | Harley Davidson Motorcycles
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Feb 20, 2014 | Electrical Supplies
Ignation switch won't turn on, dodge 2003 intrepid
Wow your going to have to take a trip to the dealer for this one only they can help you
Apr 01, 2010 | 2003 Dodge Intrepid
What sense is there in a three way switch with an off position? yes, if you turn it off the other switch will not work.
If a three way switch is wired correctly you can turn off the light or appliance from either switch as you can also turn it on from either switch. If you have two doors entering into your living room and a three way switch for the main light at each entrance then either switch can turn the light on as you enter or either switch and turn the light off as you exit.
Dec 02, 2009 | Electrical Supplies
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
135 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
