Question about Garden
I have an older homelite textron xl model 10656 and i can not seam to get the bar to hold tension long enough for me to do any thing. As soon as i make my first cut the chain comes off. As if it was bairley sitting there. Its driving me crazy. I have checked every thing i can think of. Please help.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
IS IT THE CORRECT SIZE CHAIN OR DID YOU POSSIBLY BUY A NEW lONGER ONE?
Oops sorry
when you pull the bar outweard to make teh chain tight, you have to lift the far end up and then tighten.
Posted on Dec 04, 2012
  • 323 Answers
SOURCE: The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Posted on Jun 08, 2009
  • 376 Answers
SOURCE: what is my lo hi carb adjustment for a homelite
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Posted on Jul 01, 2009
  • 4088 Answers
SOURCE: Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: Chain keeps falling off bar afterwhen saw is
Reinstall the chain. Do NOT connect power. Mark one link (chalk, crayon, etc.) wear gloves and try to rotate the chain one complete revolution. Is this possible? No - remove the chain and remove burrs from the sides of the drive links with a flat file.
3893c9d.jpg An IPL for your saw can be found here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Enter "111409" in the "Search for your unit by Model #:" window. Click search. Click "View Model" Click "View Illustrated Parts Diagram"
Yes - inspect the sprocket gear (KEY NO. - 11) pn 111363-01 new pn 122520-01 NLA, is it deeply grooved or perhaps worn through?
I'm going to get smacked as I have so many times before. The only thing RemingtonPower is producing today is unhappy customers. Replacement parts are exhausted. we aren't affiliated and had nothing to do with their decision to stop production.
Burrs on the chain or a defective sprocket are the most likely causes of your problem. If the gear is bad, there are no replacement parts available and I cannot help you further except to recommend you purchase a name brand replacement. Select a company you think will have replacement parts when you need them sometime in the future.
Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
Your rating of our help is the only payment we get for this service. I provided as much help as humanly possible. Punishing me for your disappointment with RemingtonPower isn't fair to me. I hope I answered your question. Thanks. A few kind words would be appreciated.
Lou
Posted on Nov 02, 2009
SOURCE: HOMELITE Textron Chain Saw, wont stay running properly.
left my chain saw xl12 in the garage and the gas dried up need to rebuild the carb and clean up the gas where do I get a gasket kit so I can start for this unit
Posted on Feb 24, 2010
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
I teally need a manuel for this chainsaw Homelite Textron UT104033. the sparkplug has alot of oil in it? and im, not sure how much tension is supposed to be in chain? obviously i cant seam to get it to...
Here is a helpful link for the owners manual and maintenance guides. The chain should be tight, but still have some movement when you lift the chain from the guide, however the bottom links should not come out of the guide.
http://www.homelite.com/catalog/chainsaws/UT43100
Aug 29, 2011 | Garden
I have an earlier model Homelite XL Textron, UT#: 10618A, Serial#: 7D2080207. I need to replace the chain and possibly the bar. Can you tell me where I can get a chain and/or what is the part # for the...
Hello cf:
I need your help to help you.
Please count the drive links on an existing chain and post back (below) with the number. I have to close this, to post a photo. We can continue if you just reply.
I will provide the correct bar size and a link where you can make a choice, because your saw is so old I cannot match it to anything currently on the Homelite site and I am not willing to recommend a chain without seeing your level of expertise.
You can also take an existing chain to a local saw shop where one can be fabricated in a few minutes.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 26, 2010 | Homelite Garden
I recently bought a 12" homelite xl textron chain saw @ yard sale. it runs good but leaks gas. it has a hole in top of gas tank, it looks like a factory drilled hole with nothing in it. is this hole for...
I dont know where the fuel is leaking from but i`ll make a guess and say the fuel lines are perished.NOW all you have to do is disassemble it taking note of where every thing goes and replace them ALL.... not hard just have a good look at where things go before pulling them apart , you will manage
Aug 25, 2009 | Garden
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Jul 01, 2009 | Homelite Garden
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Jun 24, 2009 | Garden
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
183 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
