HEIL MAX PERFORMANCE 10 -RATED VOLTAGE 508-530...WHAT IS THE TON OF THIS UNIT?
HEIL MAX PERFORMANCE 10 CENTRAL AIR OUTSIDE UNIT, RATED VOLTAGE 508-530. hOW MANY TONS IS THIS UNIT?
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
james3751
  • 614 Answers
SOURCE: Heil Max Performance 10 Heat Pump not working
First check to see if you have afloat switch inside the air handler ar underneath the air handler. Its purpose is to shut the outside ac off if the drain stops up. Very common. If this is OK take cover off unit and with screw driver push in the contactor. It is located about the middle of the panel. It has main power at the bottom. If unit comes on you cave a control voltage problem. Meaning something is not allowing 24 volts to the contactor. If your out of Refrigerant the low pressure swich will have it off. Call a service tech. Rusty
Posted on Jun 09, 2009
  • 308 Answers
SOURCE: The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Posted on Jul 28, 2009
SOURCE: Voltage Stabilizer for LG 1.5 ton window type ac
4KVA capacity stabilizer is sufficient for 1.5 Tonne AC.
Posted on Apr 14, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: Hello I have Heil A/C unit, and I'm looking to
30,000 btu, 2.5 ton
Posted on Apr 22, 2010
Testimonial: "Quick accurate response to my question. Very helpful. Thank you"
How do I find the fuse for central air type is a heil
There's a small 3 amp fuse in the air handler (indoor) that protects the control transformer (there should also be internal circuit breakers and a disconnect outside). The condensing unit (outdoor) is protected by an outside disconnect and circuit breaker.Be sure to shut the power before messing around in the air handler.
Aug 21, 2013 | Heating & Cooling
How long is the compressor in my heil max pro 10 waranty good for
Not sure which model number the Heil Max Pro 10 warranty uses. Heil will usally place the model number on the side of the outside unit or inside the cabinet for thee Inside unit. Click here for a direct link to=> Heil HVAC
Use care when reading any warranty because the wording is mostly written so you do not understand.
To help you decide which Heil product and warranty protection is best for you, select from the following at-a-glance comparisons.
Please let me know If I can help you with other question, Thank You, Sea Breeze
Aug 31, 2011 | Heating & Cooling
Heil central a/c will not turn on, model is max performance 14 model # HAC442ACK4. checked circuit breakers
Hello, if the outside unit is not running start at the outside disconnect box and verify if you are getting 240 volts, if you are continue to the contactor coil, check for 24 volts at the contactor coil if there is 24 volts and the contactor does not energize then it must be replaced. If you do not have 24 volts then the low voltage ( thermostat) wiring must be checked out for a short circuit, loose wiring, or the thermostat might be bad. Also, you can check for 24 volts at tjebcontrol board between the r and c terminal if no 24 volts then you have a bad transformer.
Apr 27, 2011 | Heating & Cooling
I have (2) two 10 ton Air Conditioning units for central air and central heat. Which are: (2) Air-handlers upstairs and (2) pad mounted units outside. Each one has its own thermostat. I need to have...
You could do it with a wireless thermostat and just have 2 thermostats right next to each other with a sensor for the other one. I think that's your best option, look into a wireless thermostat.
Feb 08, 2011 | Heating & Cooling
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
Jul 28, 2009 | Heating & Cooling
Jun 09, 2009 | Heating & Cooling
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
