Need to replace the lamp in a roto globe v-8106
2 Suggested Answers
Marrie
  • 563 Answers
SOURCE: removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Posted on Mar 26, 2008
Harbor Breeze Portes ceiling fan. How do I replace the lamp?
Check a home-depot store, if you see a similar fan, ask for the sales person to show you.
Jun 26, 2015 | Dryers
Lamp cord stuck
Hi Henry,
To replace the cord, you need to be able to secure the wire at the globe end, usually by screws. You need to be able to get at both end of the arms - the globe end, and the center where the arms join.
Remove the globe end where the wires attach, and see if this releases the wires. It is easier to draw wires through an arm than to push it, as the wires will bunch up.
I would use a solid steel wire - like fencing wire that is fine enough to go into the arm, and not as flexible as the copper wire for the light.
Use this to push the wires through the arm, or make a small hook on the wire so it will go through the arm, and hook onto the stuck wire to draw it out.
Feb 01, 2014 | Electrical Supplies
Show diagram of globe
This set it is reported may have been made by Sony--the owner manual will show where and how to replace the lamp if needed.
May 16, 2012 | LG DU-62SY20D 62" Rear Projection HDTV
Please, i need authorization number of Adobe Photoshop CS2 serial number: 1045 - 1088 - 8780 - 9638 - 3061 - 1396 activation number : 4438 - 6677 - 7036 - 7773 - 8077 - 7126 - 8106 thank you!
Adobe Photoshop CS2
authorization number:- 0577 4174 1425 7327 7257
Aug 29, 2011 | Adobe Photoshop CS for PC
My PLV-Z2,globe will not light up,power up to
ballast and/or lamp is bad and needs to be replaced. the ringing sound is high voltage issue.
Oct 04, 2009 | Sanyo PLV-Z2 Multimedia Projector
How do i replace the lamp on the kf 50we610
Sorry, they misinformed you!
On this model Sony the lamp access is located to the side of the set. You will see a small hook you can push down with you finger releasing the lamp outer cover. There might also be 1 screw to remove the panel.
Now you will see the lamp inner cover. It has a grey handle in the middle of it - to dark to see down there, get a flash light. Remove this by turning it counter clock wise. Now pull the cover out. Note the chip on the one corner of the cover. It can only fit back the same way.
Now you will find a slot you can fit your finger into. Pull this down and pull the old globe out.
FYI - If the globe has burnt leaving a white discharge behind inside the globe - great, your TV is healthy. If it blew with a black discharge I would suggest you take a hear dryer on cold setting and blown as much dirt from inside the globe cavity as possible. also try not to switch your TV on and off to often. If you leave the room and you know you will be back within a hour, leave the set on. You will much easier reach 8000 hours of globe life. 8000 Hours is possible, I have seen it before.
Now place the new globe into the socket. Just push it in until you feel the locking mechanism engage. Return the inner lamp cover. Turn the grey lever clockwise.
Now all that is left is to clip the outside cover into place. Put the screw back if there was one.
If you have to remove more than 1 screw - you have gone too far.
P.S There are certain lamps that does not have a clip, but rather a HEX key screw. You will receive this hex key if you bought a genuine Sony globe in the box.
Good luck.
Jul 21, 2009 | Sony XL-2100U Projector Lamp for...
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Removing the "lamp needs replacing" warning message
Hi guys
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
35 people viewed this question
k24674
