Question about ASUS Computers & Internet
I am using my laptop with an external mouse. Every so many seconds, the mouse is stuck, the cursor wont move, all that followed by an annoyins sound from my computer telling me something is obviously wrong. but i dont know what. can you help? that would help a lot.. thanks
  • ASUS Master
  • 7,627 Answers
Which OS are you using? Driver? Try removing the battery and usb. Reboot, Install battery , install usb. Is the annoying sound the usb disconnect?
Posted on Dec 03, 2012
  • 6 more comments
  • Tomer Gardi Dec 04, 2012
    Thanks Max. I tried this, didn't help though. The annoying sound is indeed the usb disconnect sound. I removed the battery and usb, rebooted, still the same. I am using Windows 7 Home Premuim, with an Intel CORE i3 CPU Proccesor. If you have any other sugestions, please...oh, and i tried the bellow suggested sollutions. does not solve the problem. thanks
  • max carson
    max carson Dec 04, 2012
    The drivers are up to date? Then I would try another Mouse and USB, perhaps it is defective. The computer is "seeing" a disconnect/reconnect?
  • Tomer Gardi Dec 05, 2012
    thanks a lot, I am using a different mouse, which seemed to have solved the problem. thanks again.
  • max carson
    max carson Dec 05, 2012
    I have noticed my old external USB Logitech mouse has started doing the same thing, Go figure.
    contagious...
  • max carson
    I suppose? Stranger things have happened. Got any ideas how I can fix this problem.
  • Tomer Gardi Dec 06, 2012
    get yourself a new mouse.. worked for me.
  • max carson
    max carson Dec 06, 2012
    Good idea. I find this quite annoying.
3 Suggested Answers
haayz
  • 197 Answers
SOURCE: Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
Posted on May 29, 2009
  • 7 Answers
SOURCE: acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Posted on Mar 30, 2010
The cursor will not move and I cannot use the laptop at all.
The cursur moves from the sensory pad, if the pad went out the cursur will not move.. I would start by installing an external wireless mouse or even a basic plug in mouse to the usb port and see if you can cntrol the cursor then. Cheap wireless mouses with a small included usb donggle can be used in place of the sensory pad cursor
Oct 07, 2012 | Computers & Internet
Cursor won't move on my Acer laptop
Dear Friend,
On your desktop press the following key conbination: Fn + F7 if not, there must be a problem with your mouse pad. It might also be that your OS takes time to load or freeze and it make it look that the mouse is not working. You can also try and external mouse.
Good Luck!!!
Nov 06, 2011 | Acer Computers & Internet
The Cursor of my acer is stuck and it cant move any further. what can i do?
Hi
If the cursor is stuck/frozen when we use the touchpad it can be solved by the following method.
Switch off the laptop, disconnect it from power, remove the battery and keep pressing the Power switch for 30 seconds.
Then reconnect battery and the external power in that order and power on the laptop. the cursor will be moving again.
Please check this related discussion which is similar to your problem:-
http://www.computing.net/answers/hardware/my-laptop-cursor-wont-move/67689.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Computers & Internet
I have a Toshiba LapTop Windows 7 My granddaughter pushed keys and now i can't get the cursor to move. I have tried shutting down and it is still frozen in the middle .
Are you using the trackpad to manipulate the cursor, or are you using an external mouse?
If you're using the trackpad, it may be as simple as using the Fn keys and the corresponding F keys at the top of the keyboard to enable the trackpad feature again. If that doesn't work, try plugging in an external mouse via USB port to see if that works.
If you're using an external mouse, then try to see if the cursor moves while using the trackpad.
Hopefully one of these options will give you control back over your cursor again.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
My cursor is frooze and wont move? i have taken the battery out but its still in the same place.. any ideas?
On many laptops, the touch mouse can be deactivated so that a external mouse can be used. It is typically a 2 key combination using the "function (Fn)" key.
Look for any keys on your laptop that seem to have a little mouse icon and press that key along with the function key.
If this does not resolve the issue ... you can also try an external mouse and see if that moves the cursor.
Dec 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Stuck cursorDell Latitude D600 laptop.
using touchpad or external mouse..I would check into updating the drivers for the mouse
www.aa1consulting.com
Jul 26, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Mouse cursor wont move
most laptops have a way to enable/disable the touchpad for those that use an external mouse or do alot of typing and encouter the overactive touchpad.
hold the "FN" key and press the corospinding function "f button" to enable it.
the function key number will be different depending on your laptop and you should also check the laptop base for a button that may be specifically for this purpose.
Good Luck and Happy Hunting!! :)
Mar 10, 2009 | LG X-Note LM50 Notebook
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Cursor is frozen on the lap top
try using your external mouse to reinstall the touchpad driver. in almost all cases i've seen of this it has fixed the problem.
hope this helps
Jan 16, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Erratic cursor
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
Oct 22, 2008 | Toshiba Tecra M1 PC Laptops
Computers & Internet Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
