Question about HP Pavilion Dv7-1232nr Dv7-1135nr 17.1" Wxga Lcd Screen Complete Lp171wp4
HP pavilion dv7-1135nr turns off with no warning when plugged in
My friends computer stopped working. Lights where blinking. I replace the motherboard (but not the cpu) It is now working but after several minutes in cuts off, with no warning. It is hot on bottom, everything was clean. Can not hear fan so not sure if it is working or not. I did not change anything in bios. I am going to see if I can see fan working or not. Do you think the cpu is bad? or a bad motherboard?
  • Damon Dec 05, 2012
    Installed speedfan. Cpu was almost 200 degree. Fan not working. Ordered new fan.Will let you know if that fixes the problem.
  • HP Master
  • 2,084 Answers
Bingo.
the first step is clean out all that lent!
its a job to do every year,
that lint packs the vents and even the tiny heatpipe radiator
and can even stall the fan...
this is like , basic basic basics PC101... all do that.
ignored.
why not go to youtube and ask there, search
and see a zillion hits on this topic, its really endless.....
Posted on Jul 28, 2017
    Habit-Forming:
    New Friend:
  • 28 Answers
Neither, if it is hot, its because the fan is not working. Overheating will cause shutdown. Also, cleanig it would help dissipate heat when you replace that fan.
3 Suggested Answers
DickCanFixIt
  • 948 Answers
SOURCE: Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Posted on Jul 10, 2009
  • 134 Answers
SOURCE: HP nc8230 no BIOS setup and system time error
the simple thing is that are the both system compartible?so if they are not just compartible go to the local pc outlet in your area and get a compartible one better you go with the faulty screen so it could be easily verify.
Posted on Sep 18, 2009
Hp p6530z desktop will not boot
It could be the monitor. Try a different monitor. Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 02, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My hp pavilion dv7-1135nr turns off with no warning when plugged in
Get a program called speedfan and try to install it before it crashes, put it in the refrigerator to extend the run time. Almico.com has the free application speedfan. that program will tell you what the temps are. You could also look at the event viewer logs to see what they say under the system tab. The bios changed when the motherboard changed. However it sounds like an overheating issue. Did you put new heatsink compound on the CPU
Jul 26, 2017 | HP Pavilion Dv7-1232nr Dv7-1135nr 17.1"...
Hp dv4000 won't turn on, no lights on- totally dead
first check fuse in plug. if good then check power adaptor, even if its lit up it still can be faulty or use a voltmeter to check that you are getting continuous current. if good it gets harder youll have to open it up and check the fuse inside it dont look like a normal fuse its small. its at the back next to were you plug in the charger should say f. check picture. its not for youre model but just a demonstration. hope this helps. j.oates
Nov 16, 2012 | HP Pavilion dv4000 Notebook
Hp laptop doesn't turn on, no lights
From the description it is a motherboard failure, only option is replacement.
Apr 30, 2012 | HP Pavilion dv1010us Notebook
Monitor does not turn on. HP Pavilion f1903 Switch light just continues to blink
Reseat the connection of your video card from the motherboard.
If problem still continue, try using different video card on your motherboard and see if it works. If the display is OK then you will be needing to replace your video card permanently.
May 26, 2010 | HP Pavilion F1703 17" LCD Monitor
I can't turn it on. it turns on for a second then off
Seems like the baterry is dead If the battery light blinks orange plug the ac battery adapter into the computer and into a outlet.
Dec 04, 2009 | HP Pavilion tx1000z Notebook
HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Feb 02, 2009 | HP Pavilion dv4000 Notebook
HP a350n not powering up.
unplug power and open computer and pull the small battery and wait 30 sec and replace
plug in everything and reboot
may have to re-enter cmos utility
Aug 24, 2008 | HP Pavilion a350n PC Desktop
HP Pavilion meets monitor
I would fathom a guess that the motherboard has been damaged, if it is the PS then you can see by taking it into a service center to have the output checked 3 v 5 v 12 volt good luck.
May 26, 2008 | HP w19 19" LCD Monitor
HP Pavilion Dv7-1232nr Dv7-1135nr 17.1" Wxga Lcd Screen Complete Lp171wp4 Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
