Question about Alpine TDA-7547
I need a wiring harness for an old model Alpine TDA-7547
I have the stereo, but I need the wiring harness. I am putting it into a Toyota Corolla and I already have the wiring harness to plug into the factory wiring, but now I just have a bunch of exposed wires coming out of the car, but no way to connect them to the stereo.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
You can get one from pacparts.com or any decent car audio store. The part number is AL16-0001.
Posted on Dec 07, 2012
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
CRTN
  • 716 Answers
SOURCE: dimmer wire connection from aftermarket delco harness to alpine
One Of The Wires Should Be labeled Dash Lights That Comes Out Of Your Radio.
Posted on Mar 11, 2009
  • 152 Answers
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Posted on Mar 22, 2009
  • 3 Answers
SOURCE: Need owners manual of TDA 7547 Alpine car stero
To change AM to FM, hit the White Band Prog button. Still don't know how to change time though.
Posted on Sep 16, 2009
  • 3 Answers
SOURCE: How do I preset the stations for an Alpine TDA-7547 car Stereo
Select the station you want. Then hold down one of the 6 preset buttons for a couple seconds. When the station ID flashes, release the button and it should be saved.
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
How do i take out my radio from my toyota corrola
The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
    > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
    > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
    To install
    > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
    >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
    > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
Dec 05, 2010 | 1990 Toyota Corolla
I am trying to install an aftermarket cd/radio into a 2001 Toyota Corolla GS which has a standard radio console
I would get a stereo installation kit for your car from Auto Zone or a local car audio store. It will have the surround for the new stereo to fit where the old one was and a harness that you can wire the new stereo to and the harness will have a plug to match the stock radio plug.
Jun 05, 2010 | 2001 Toyota Corolla
I dont no how to connect wiring for alpine stereo model tda 7548e
Theres a standard amongst most stereos, so if these colors apply, then you will be right,
Red is Ignition power
orange is direct power
Black is earth
blue is for phone
White is for electric arial
then there will be four coloured wires with matching color trace wires, these are the speaker wires.
Hope this gets you going, good luck.
Jun 01, 2010 | Alpine TDA-7547
Hi i have a toyota car stereo, model number 08600-00610.. Do you have the manual for the wiring of this stereo?? Thank you so much.
if you plan to put in a new stereo do not splice the wires get the hardness cuz if you splice it too much you will need to run new wires
Dec 27, 2009 | Buck Toyota Corolla 1991 Stereo/radio...
Need owners manual of TDA 7547 Alpine car stero . Cant't figure out how to set clock and change am to fm.
Mar 07, 2009 | Alpine TDA-7547
Backlight on LCD display of Alpine TDA-5747E car radio gone
Here's the manual:
http://www.alpine.com.au/downloads/web_owners_manuals/cassette_owners_manuals/TDA-7548E_TDA-7547E.pdf
Jan 16, 2009 | Alpine TDA-7547
How do I preset the stations for an Alpine TDA-7547 car Stereo. This is an older stereo and setting the stations is not intuitive.
Dec 06, 2008 | Alpine TDA-7547
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
Installing rear speakers
You need a pair of alpine radio removal keys which get inserted in the slots along the sides under the trim ring. Any Car stereo shop should have them for free(ish).
Sep 09, 2007 | Alpine TDA-7547
Car Audio & Video Logo
101 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
