Question about Maytag Washing Machines
Maytag Washer Model# LAT 7793AAL, stopped spinning, smell burning?
Model# LAT 7793 AAL, stopped spinning before rinse cycle, smell burning?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Check the belt and pump to see if it is locked up.
Posted on Dec 03, 2012
marka19
  • 1430 Answers
SOURCE: Washer stopped working and smells like it's burning
This would be the motor coupler that has failed common problem and easy to fix. There is a video ( whirlpool style) that will walk you thru the troubleshooting and replacement at www.appliancehelponline.com/servicemanual.html
Posted on Mar 27, 2010
IFIXALL
  • 868 Answers
SOURCE: maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
Posted on May 23, 2008
Lumpy816
  • 246 Answers
SOURCE: Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
mrbobfixit
  • 259 Answers
SOURCE: LAT 7793 ABL model number.
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Posted on Jul 01, 2010
How do you ascertain if its drain pump or faulty controller board causing a fault 37 on a gw612?
Read the answer in the link below first, but in your case it can also be a faulty or blocked diverter valve. If you are good with a multimeter check the resistance of the pump windings. It should read around 33 ohms. It is not uncommon for the pumps to cook themselves and you can smell and see the burned out motor. I hope this is of some help
http://www.fixya.com/support/t25754844-error_code_37_fisher_paykel_8_5_kg_front
Jul 24, 2015 | Fisher and Paykel Washing Machines
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
Burning smell
check belt
Jan 09, 2018 | Dryers
Maytag washer lat8600
That model doesnt come up on Matags web site?
Nov 25, 2013 | Whirlpool Washing Machines
I have an issue that is rather strange! On the NORMAL cycle only, at the end when it should turn off, a rinse comes on and wets the clothes. The extra rinse is NOT on, the belt and motor are fine. I know...
Always supply a model number, each model has it's own foibles. It is very hard to assist without full details.
BUT, is this an "LAT" series Maytag washer??
If so, this is a normal rinse, the manufacturer calls it a "Spray Rinse" and it is quite normal.it only adds the water during the spin cycle, after the rinse water is ejected and then only for about 1 minute, the water passing through the fabric as it passes by the water inlet flume and empties during the spin.
Jun 12, 2017 | Maytag MVWC6ESWW Washer
Washer smells like burnt rubber
What is the make and model of your washer? I had a similar problem with my Maytag - there was a burnt resistor on the control board. We ended up just buying a new washer since the cost for parts alone was close to $400...the labor would have been a DIY-thing (15 minutes easily for the greenest amateur).
Nov 28, 2011 | Washing Machines
Washing Machines Logo
176 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
